fan question
wvsquirrel
Gold - Posts: 1,237
Posted: May 09, 2003 at 12:39 AM / IP Logged
equalizir wrote:
hey wvsquirrel,i have a distro block but its a 1 input to 3 output.could i add the fans and crossovers to the outputs im already using?i have the three ouputs going to amps.so i guess it would be like piggybacking off those outputs.thanks
Running it that way should be ok because you're splitting the current before it gets to the amp itself. If you do it that way, then I would suggest using the distribution block output that is going to your least powerful amp.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
