dball + viper 5704 + vsm200, connectioné
wup123
Member - Posts: 7
Posted: January 01, 2013 at 1:34 PM / IP Logged
I was just wondering how to go about connecting this all together. They all have a D2D port, and the 5704 and VSM200 have a bit writer port. Will it work if I hook it up as follows
VSM200----(bit writer)----5704---(D2D)----DBALL
Or is there another way I should be hooking them togetherÉ
shortcircuit161
Silver - Posts: 556
Posted: January 02, 2013 at 11:32 AM / IP Logged
Yes that is the correct way to do it.
You would connect the DBALL using the D2D cord direct to the 5704.
You would connect the VSM200 to the bitwriter port. You would not use any of the other data plugs from the Y-adapater on the VSM200.
Tuesday, September 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
