xpresskit pkall programming issues
garrettc88
Posted: February 15, 2013 at 11:17 AM / IP Logged
ok so i have done a few security/auto start systems in the past but this set up has really been giving me some issues. i have a viper 5204 security/ remote start in my 2001 honda accord the security system works fine and i am installing the xpresskit pkall and the 530t window automation system now... the problem i am having is.... i have all the connections made to the immobilizer on the car and the D2D port connected to the viper but i cant get threw programming. i get to step 7 and instead of just flashing once for the honda/acura selection it flashes continually and when i turn the key on i just get a solid light no flash 10 times. any info anyone can give me on this issue will be GREATLY appreciated....
garrettc88
Posted: February 15, 2013 at 11:18 AM / IP Logged
2001 honda civic********
Chris Luongo
Platinum - Posts: 3,746
Posted: February 16, 2013 at 8:53 AM / IP Logged
I would test the ignition wire on the module. The flashing starts when the key gets turned on....so maybe the yellow wire isn't getting ignition power.
garrettc88
Posted: February 16, 2013 at 12:18 PM / IP Logged
i actually had the data wire and the ground while running wires mixed up... blue/white and dark blue/white. should have looked closer the first time...
