folding mirrors
t&t tech
Platinum - Posts: 2,610
Posted: February 28, 2013 at 10:13 AM / IP Logged
i already have a method to accomplish this but maybe someone can suggest another method. I wanna get my mirrors folding in when the ignition is turned off, and out when it's turned on.
Posted: February 28, 2013 at 1:12 PM / IP Logged
What vehicle sunshine?
Two methods if standard wiring, think adding actuator in the Relay section.
Either use a pair of timed outputs from an alarm or a pair of 528ts from the ignition watch this space:- 837_mirror_fold.bmp
Set the 528ts for 1 second longer than it normally takes them to fold and unfold.
PS Mitsubishi uses a different system, a POS (+) pulse on 1 wire to fold, then a POS (+) pulse on another to unfold hence what vehicle.
You knew Uncle Howard would come to the rescue didn't you.
Monday, July 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
