fuel system hook up for a 2.3l efi turbo
jaykul
Posted: March 07, 2013 at 5:10 PM / IP Logged
I'm installing a 2.3l turbo from a 88 t-bird into an 85 ranger that had a regular 2.3l carborated engine. The problem i'm having is how to hook up the fuel system. i was thinking on using an inline fuel pump and using a fuel filter that has a return line to it. The basic problem is how to hook it up. do i put the filter before the pump or after it? if it is after the pump wont it cause problem with the return flow?
oldspark
Gold - Posts: 4,913
Posted: March 07, 2013 at 5:29 PM / IP Logged
Since the return flow is independent of the supply, no.
And the filter is before the pump, though I have a 2nd before the carby just as engines with EFI do for the injectors.
Make sure you have a suitable pump - eg, progressive pressure if its a push thru or injectors, and HP filters & lines to suit.
But try a car forum instead - unless you have a 12V turbo.
Thursday, October 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
