04 neon xpresskit
danc75
Member - Posts: 10
Posted: March 10, 2013 at 3:34 PM / IP Logged
For some reason i cannot get a proper diagram to hook up this solo on this car and i cant seem to get it to work
Help pls
yellow_cake
Copper - Posts: 178
Posted: March 10, 2013 at 3:39 PM / IP Logged
Which model of xpresskit poduct is it?
danc75
Member - Posts: 10
Posted: March 10, 2013 at 3:46 PM / IP Logged
Ots a solex xk09 with dlch3 firmware
danc75
Member - Posts: 10
Posted: March 10, 2013 at 5:02 PM / IP Logged
Ive tried going to the light green wire in kickpanel and to the wire on the data plug and cannot get this bypass to program
Ideas would be greatly appreciated
yellow_cake
Copper - Posts: 178
Posted: March 10, 2013 at 6:30 PM / IP Logged
XK09 will not bypass the transponder system on this car and is only a door lock, trunk, etc module.
If that is what you're using it for, let us know which wire of the XK09 you have connected where, and what is the exact problem you are having at which step?
yellow_cake
Copper - Posts: 178
Posted: March 10, 2013 at 6:35 PM / IP Logged
Install guide can be downloded from the install guide link beside the XK09 listing on the website http://xpresskit.com/VehicleCompatibility.aspx?p=null&year=2004&make=Dodge&model=Neon&ps=1&s=0&c=0
danc75
Member - Posts: 10
Posted: March 10, 2013 at 6:55 PM / IP Logged
yteah, i went by that in the first place and i can`t seem to get it to work???
yellow_cake
Copper - Posts: 178
Posted: March 10, 2013 at 9:48 PM / IP Logged
shortcircuit161
Silver - Posts: 556
Posted: March 10, 2013 at 9:59 PM / IP Logged
You just said "I can't seem to get it to work". What exactly isn't working?
danc75
Member - Posts: 10
Posted: March 11, 2013 at 11:54 AM / IP Logged
Well the place i bought it from told me it would work and is programmed to this car to bypass the key
As in i cannot get it to work means that it will not program for this feature but if it only works for locks and not as a bypass that would make sense???
Tuesday, July 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
