wiring and amp
higgssauce
Posted: March 21, 2013 at 4:31 PM / IP Logged
I have 10 selenium 6w4p 6 inch speakers, they are 8 ohm and 200 watt/100 cont.... I am wondering how to wire them and what is a good reasonable priced amp to push them? If it helps I will be putting 2 in the dash and 4 in each of the 2 doors....
namesmeanlittle
Member - Posts: 10
Posted: March 21, 2013 at 7:38 PM / IP Logged
ok so i have no clue what highs you have or want
but if your all hell bent in using 10
no prob
8 would be best for wiring options
for straight subs and lows i have a mtx td 1000
it would do perfect its mono may be more that what you need cheap though only about $300 would wire it 5 rows and double up the subs use 16 gage wire at minimal to prevent ohms from the wire killing your sub input levels
i have no clue what mids will sound like on the amp may not do well
if your after the whole 2 channel mid bit as well
just bumming around
Coustic 300W RMS 4-Channel Amplifier for 8 subs split to 4 ohms
suppose to sound better
