alarm output
recks
Member - Posts: 9
Posted: May 06, 2013 at 2:53 AM / IP Logged
Hey guys I have a quick question, I was wondering if I can use my alarm output for more than one use? For example starter kill, window roll up?
Posted: May 06, 2013 at 7:13 AM / IP Logged
Define alarm output.
Are you talking about NEG aux outputs?
If so then yes of course.
Platinum - Posts: 13,726
Posted: May 06, 2013 at 11:29 AM / IP Logged
The starter kill output of the alarm has ground on it the entire time that the alarm is armed. As long as your window control module is good with a constant ground, you will be fine. If not, you will need to try and find a diagram that will convert the constant to a pulse without flattening (For Howie) your battery.
Posted: May 06, 2013 at 11:31 AM / IP Logged
OK Craig, what do the colonials call it, draining?
recks
Member - Posts: 9
Posted: May 06, 2013 at 11:33 AM / IP Logged
Yes sorry i should of added that extra detail on my arm its labeled: Armed Output(-) 500mA.
Posted: May 06, 2013 at 11:36 AM / IP Logged
That would be good for window closers such as the DEI 429t and 530t but not for a remote start, you would need a momentary output.
What alarm?
recks
Member - Posts: 9
Posted: May 06, 2013 at 11:39 AM / IP Logged
What alarm?
No remote start i know i have to use an AUX output I'm taking about a Starter Kill.
Posted: May 06, 2013 at 11:44 AM / IP Logged
So use this diagram, a 1N4004 diode and a 5 pin Bosch/Tycho cube type automotive relay.
The orange wire in the diagram would be your armed output.
