avital 5303 start die
fastblkcat
Posted: May 23, 2013 at 11:10 PM / IP Logged
Hello first time posting here... I just installed a avital 5303 on my 2001 f250 super duty. Its all hooked up and working even the door locks.... that took a bit of thinking to figure out.. but now when remote started it starts runs like 2 seconds and shuts off... truck has no security system no pats key just steel key... when run the start kill diag on the avital says code 4 (remote shut off) the two way remote does beep and show shut down... not sure what could cause this... any thoughts on what I might be missing ?
smokeman1
Platinum - Posts: 1,589
Posted: May 24, 2013 at 6:37 AM / IP Logged
Did you do the TACH LEARN for the 5303?  Page 32 of the install manual.  What is the TACH wire conected to on the truck?
fastblkcat
Posted: May 24, 2013 at 8:36 AM / IP Logged
I have but may not have worked as I just learned its in bitmap mode so will switch it tonight and try that again...hopefully that works I'm hooked to a injector driver wire thank you for replying
