2013 honda crv with omega au 93 4
wonderroma
Member - Posts: 6
Posted: July 04, 2013 at 12:39 PM / IP Logged
Getting ready to add an Omega AU-93-4 window module to my wife’s crv. After reading the instructions from the download section have a few questions,
1) Does anyone have a wiring diagram for the windows; I’ve been looking with no luck. I can take it apart and test it but I’d rather know what I’m doing when I start.
2) If the system is not rest at ground I will need relays and I’d like to know that before I start.
3) Does anyone see a reason why I can’t use a second module triggered by an auxiliary on my Viper 4704 to roll the windows down.
Thank You
Posted: July 04, 2013 at 6:13 PM / IP Logged
1) Motor wires, you'll be removing the door panels anyway, 2 seconds to test!
2) I'll give you better odds on winning the lotto than your windows are anything but type "A" NEG (-) at rest.
some Mercedes, VW Polo and Euro GM were pos at rest, all US and Japanese if not comfort close will be NEG at rest.
3) Absolutely not, use a second module although the much better DEI 530t is set up ready for roll-up vent and roll-down.
You will need two x 530t for 4 windows.
wonderroma
Member - Posts: 6
Posted: July 05, 2013 at 8:03 AM / IP Logged
Thank you, I appreciate your help, I read the directions for the 530T and have one more question. The H2/5 Gray (-) output during activation wire on the 530T, does that always have to be connected to a relay or only if the windows rolling up are setting off the alarm.
Posted: July 05, 2013 at 9:26 AM / IP Logged
Only if the windows set off the alarm.
wonderroma
Member - Posts: 6
Posted: July 07, 2013 at 7:47 AM / IP Logged
Thank you.
Friday, July 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
