out of range when remote started
greeky510
Member - Posts: 22
Posted: August 30, 2013 at 10:29 PM / IP Logged
I just removed every single fuse not vital to the engine running (fuel pump, injectors, o2 sensors, ignition, and coils) and still wouldn't work.
I even disconnected the alternator in case it was creating some kind of interference but still wouldn't work.
I did find something interesting though. If I kept varying the engine rpm at idle from about 650rpm to 1000rpm by pressing the accelarator pedal and only while the rpms were changing (not holding the pedal steady) the remote would work 80% of the time. That leads me to believe that there is something to do with the cars charging system. Next time I will try the suggestions above and I will also power the remote start system from an external battery so the only connections to the Jeep are those of the bypass module.
greeky510
Member - Posts: 22
Posted: November 16, 2013 at 5:50 PM / IP Logged
Last week i replaced the engine and transmission oils, transfer case and front differential fluids and spark-plugs. The remote starter has been working fine since then will all functions working.
