new alarm not disarming from remote
shelby38
Member - Posts: 14
Posted: August 30, 2013 at 7:37 AM / IP Logged
I'm installing a new alarm in a 95 f150. Everything seems to be working correctly, doors lock & unlock, system arms, but when you press the unlock/disarm button and open the door the alarm goes office. When you close the door it stops. The door trigger is neg and the alarm lead is pos so I used a relay to reverse the polarity.
The truck wiring was a mess. 2 previous alarms were installed and left in place under the dash one partially disconnected and the other the fuse was pulled and siren wire cut. I removed both the systems before I started to install this new one.
Any thoughts on why the system doesn't disarm?
triniforever
Copper - Posts: 323
Posted: August 30, 2013 at 8:01 AM / IP Logged
What brand of alarm are u using?
triniforever
shelby38
Member - Posts: 14
Posted: August 30, 2013 at 8:20 AM / IP Logged
I think its AGPtek there no name on it.
Got it on ebay
http://www./itm/221059468686?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
shelby38
Member - Posts: 14
Posted: August 30, 2013 at 8:22 AM / IP Logged
shelby38
Member - Posts: 14
Posted: August 30, 2013 at 8:24 AM / IP Logged
new alarm not disarming from remote - Last Post -- posted image.
shelby38
Member - Posts: 14
Posted: August 30, 2013 at 8:49 AM / IP Logged
also I get 3 flashes of the lights when disarming
offroadzj
Gold - Posts: 2,043
Posted: August 30, 2013 at 11:10 AM / IP Logged
Is it the aftermarket alarm going off or the factory? Did you connect to the factory disarm or just the unlock?
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
shelby38
Member - Posts: 14
Posted: August 30, 2013 at 1:36 PM / IP Logged
There is no factory system.
If I disconnect the door trigger the unlock and lock work. Still get the 3 flashes on the like on the disarm/unlock.
When the door trigger is connected doors lock and unlock but when you open the door the alarm goes off even though the system has been disarmed from the remote. Pushing the disarm/unlock button doesn't stop the alarm from going off.
racerjames76
Silver - Posts: 581
Posted: August 31, 2013 at 8:08 AM / IP Logged
Wild stab in the dark but is the unit in some sort of valet mode? Hence maybe the extra light flashes? I buy from ebay but only new items from reputable manufacturers. Hate to condemn the unit but that is what i am leaning towards... new alarm not disarming from remote - Last Post -- posted image.
To master and control electricity is perfection. *evil laugh*
shelby38
Member - Posts: 14
Posted: August 31, 2013 at 11:01 PM / IP Logged
Gave up and bought a different system and it installed fine and everything is working.
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
