dball bypass programming fail
iono2013
Member - Posts: 6
Posted: November 05, 2013 at 1:29 PM / IP Logged
Hi all,
I have 2012 toyota camry with std key, after make the connection per wiring diagram manual that i download for my car and i check the connection seem to be correct, except i didn't connect the auto headlamp and park light wire. but when its come to programming the bypass on
step 6 :< size=2 face=ArialMT>< size=2 face=ArialMT>
Turn the ignition OFF and < size=2 face=ArialMT,Bold>< size=2 face=ArialMT,Bold>remove the key< size=2 face=ArialMT>< size=2 face=ArialMT>. The LED
keeps flashing green (quickly). Wait for the LED to flash
orange slowly (this may take up to 20 seconds).  <======it's didn't do this and the led light went off completely.
does that's mean something not right or the module is bad?
blanx218
Silver - Posts: 654
Posted: November 05, 2013 at 3:17 PM / IP Logged
Is the DBALL flashed with the 401.TL5 v1.02 firmware? You can also try resetting the module and starting over.
iono2013
Member - Posts: 6
Posted: November 05, 2013 at 3:35 PM / IP Logged
I have the xkloader 2 and i try reflash a few time with the latest firmware avaiable for my vehicle and it still fail at the programming the module. if  wiring not correctly  it will show the error signal. but this one seem like bad module or d2d not communication or something. by the way i have it hooked up with viper 5701.
blanx218
Silver - Posts: 654
Posted: November 05, 2013 at 9:06 PM / IP Logged
I would triple check your connections, then try W2W
