Need help installing steering wheel tv
LuxuryLoLo
Member - Posts: 6
Posted: May 15, 2003 at 2:41 AM / IP Logged
I have a 1997 Lincoln Town Car which had an air bag in the steering wheel. I pulled the airbag out and installed a 5" tv monitor. Now my problem is that my wires keep getting pinched as I turn the steering wheel so I keep blowing fuses. What can I do to get rid of this problem? Any info is greatly appreciated. Thanks!!!
eckoblaze72
Member - Posts: 22
Posted: May 15, 2003 at 9:37 AM / IP Logged
i don't know excatly how your steering column is. but have you tried running the wire inside something protected loike split-loom or a rubber tubing.. it seems to work because its hard for it to get pinched if its rubber.
*** Isnt removing the airbag nad putting in a tv illegal??? Well airbag kill.. mite as well watch tv before...
eckoblaze72
Member - Posts: 22
Posted: May 15, 2003 at 9:38 AM / IP Logged
you got any pictures ??
LuxuryLoLo
Member - Posts: 6
Posted: May 15, 2003 at 10:46 AM / IP Logged
Thanks for the advise eckoblaze72.  You see, there is very little space between the actual steering wheel and the steering column.  I've tried split loom but it didn't seem to work for long.  It only lasted for about 3 days.  Let me try some type of rubbery material and see if this does work.  It sucks having a nice custom 5" tv monitor on your steering wheel that doesn't turn on because of a wiring problem.  The screen looks good and I've already received tons of compliments on it but what's the use if I can't fire it up.  I'm sorry but I haven't had time to take pics.  Anymore suggestions are REALLY appreciated!!!  I like your quote by the way.
audiomechanic
Silver - Posts: 388
Posted: May 25, 2003 at 9:23 AM / IP Logged
what you can do a lot of the time is use the air bag wires to get your power and ground and what not up to the tv.
philaf
Copper - Posts: 93
Posted: May 29, 2003 at 11:27 AM / IP Logged
have you actually taken the steering wheel completely apart, or did you just put the screen in while it was still on the column? if you've taken the thing off, you should have seen a cavity going down near the center of the thing... you would figure that if they can get radio controls and cruise on the wheel, not to mention a horn, they'd have to have somewhere to run the wires...
LuxuryLoLo
Member - Posts: 6
Posted: May 29, 2003 at 1:27 PM / IP Logged
I know I should have used the wires that were in there in the first place for the horn and cruise control but I yanked everything out before I figured that out......stupid of me!!!  Yes I have removed the whole steering wheel out.  I've had several shops take a look at it and none of them can come up with a solution.  I've just about had it with this tv thing!!!!
hotrodelectric
Copper - Posts: 112
Posted: May 29, 2003 at 11:54 PM / IP Logged
What about using the clockspring?
LuxuryLoLo
Member - Posts: 6
Posted: May 30, 2003 at 2:55 PM / IP Logged
There is none, the car had some other type of wiring but my stupidness threw it all away.  Where can I find one?
hotrodelectric
Copper - Posts: 112
Posted: May 30, 2003 at 10:30 PM / IP Logged
Best bet is the dealer, of course, but I know they're going to get their pound of flesh. Depending on where you're at, the next best thing is a late model boneyard- but you'll want a car that's been centerpunched or stuffed in the rear. You can also try eBay. Another suggestion is try looking for a Crown Vic or Grand Marquis- I think the columns are the same, but check first. Also, you're not limited to '97- I think '96-'03 is the same. Again, check first. A standard one may carry enough leads to cover power and both sides of your video signal- most clocksprings are set up for power and ground to the bag, and horn. Remember to get the all of the associated wiring that goes with it!
Now- when you find one in a wreck, do not just jerk it out- it MUST remain centered in relation to the position of the front wheels. The best way to do this is steer the wheels straight ahead, then remove the clockspring. I have to do to a boneyard run tomorrow, I can have a quick look and see if I find anything.
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
