94 jeep grand cherokee, factory keyless
burntkat
Copper - Posts: 159
Posted: December 24, 2013 at 9:11 AM / IP Logged
The wife drives a 1994 Jeep Grand Cherokee (ZJ). We bought it used in 2002. It has the factory keyless entry as evidenced by the receiver globe in the headliner console, but there's never been a keyless entry fob.
So I have what might be the worst of two worlds when it comes time to install my remote start and alarm system (just installing for convenience features): A factory keyless entry and possibly alarm, with the need to delete/bypass it, having no remote for it.
How does one verify the factory bit is there, and will this be overcomplicating things?
Platinum - Posts: 7,827
Posted: December 24, 2013 at 12:16 PM / IP Logged
Shouldn't be a big deal. As long as it has factory power locks, you should be good to go.
To test for a factory alarm :
Start the Jeep with the key.
Roll down the drivers window.
Turn off the Jeep.
Open the drivers door and press the door lock button.
Close the driver door.
Wait two minutes.
Reach in the open window and use the inner door handle to open the driver door.
Any horn beeping?
There is no ignition immobilizer system, so you won't need a bypass module. The power locks are Type A (+), so depending on the
aftermarket system you install, you might need relays or a Directed 451M door lock module to convert polarity.
Here are a few resources for wiring information...
The 12 Volt : https://www.the12volt.com/installbay/vehicles.html
Bulldog Security : http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
Audiovox : http://techservices.audiovox.com/AccessRequest.aspx    Requires free sign-up.
DEI : http://www.readyremote.com/main.asp
burntkat
Copper - Posts: 159
Posted: December 24, 2013 at 1:54 PM / IP Logged
Kreg, you Sir (I assume here), are a lifesaver.
Thanks for this, going to go test now...
burntkat
Copper - Posts: 159
Posted: December 24, 2013 at 4:09 PM / IP Logged
Going by that info, there is no factory alarm system, making things easier.
There are door lock actuators, so that helps too. (I've been the route of making non-PDL into PDL via adding actuators. Lots of work, that!)
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
