Bulldog RS602E help.
SoulREX
Posted: May 15, 2003 at 11:53 PM / IP Logged
Hey guys, I'm installing a Bulldog RS602E in a friends car, and I don't know what to do with the shock trigger inputs.. He bought the dual stage shock sensor, and a dual stage dopplar sensor, but the RS602E only has a one wire trigger, not dual. I wanted to know if there was a simple circuit I could build from relays to make use of the dual stage by kicking the siren trigger line a few short times to simulate a pre-warn tone. Any help would be appreciated. TIA -Sean
SoulREX
Posted: May 29, 2003 at 10:56 AM / IP Logged
No one has any help they could offer? I just need ideas on a simple relay ciruit to intermittantly hit the siren to simulate a pre-warn... thanks..
bdl666
Silver - Posts: 330
Posted: May 29, 2003 at 1:56 PM / IP Logged
                               Does the sensor have an adjustable trigger time or is it just a pulse output. If it has the adjustment all you need is a relay and a flasher(signal lights flasher).
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
