switching an amp
alt29040
Member - Posts: 7
Posted: June 17, 2002 at 4:58 PM / IP Logged
I have an install that the owner wishes to put a switch on the amp to cut it off seperately from the deck, not just signal but power, completely off . Iam wondering what options i have. can i cut signal in the remote lead with a switch and that do the trick or do i have to go in to the power lead? A relay application maybe better? all suggestions welcome .
a.l.t.
bberman1
Gold - Posts: 2,314
Posted: June 17, 2002 at 5:14 PM / IP Logged
You can put a switch on the remote wire and it will turn on and off the amp. You do not need a relay to do this and don’t need a switch on the power wire. The remote wire is what turns the amp on and off so if you cut the power to the remote wire it will turn off the amp.
alt29040
Member - Posts: 7
Posted: June 17, 2002 at 5:19 PM / IP Logged
hey thanks for the help. I am just begining to install in other vehicles besides my own and wanted to be sure. I am working on mecp cert. and hope i won,t have to ask quest. like this in a few months once again thanks for the helpswitching an amp -- posted image.
a.l.t.
NyxBass
Silver - Posts: 226
Posted: June 17, 2002 at 5:42 PM / IP Logged
Everyone has to ask at some point. That's why we hang out here!
/NyxBass
Tuesday, December 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
