ford n.c door trigger
pts760
Copper - Posts: 403
Posted: December 10, 2014 at 10:38 PM / IP Logged
I did a 2012 Ford Mustang MT Remote Start. I used tech Doc 1921 under the download section to interface the door triggers. My unit only had a negative door trigger input so I had to wire the 1921 tech doc to a PAC TR-7 to a relay to convert to a negative door trigger. For some reason the wiring with the 1921 Doc didn't have enough voltage to trigger the DEI 8616 relay and that's where the TR-7 came into play.
Anyways my question has anyone wired the NC ford door trigger to have a negative door trigger instead of a positive or is it even possible. The negative trigger would have saved me time and money.
I drink current, eat ohms, and bleed voltage
tedmond
Gold - Posts: 4,610
Posted: December 10, 2014 at 11:15 PM / IP Logged
why not use the dome light wire and convert that to negative?
gray/purple (-) or (+) depending on model @ passenger kick
what unit?
Ted
Compustar Expert
pts760
Copper - Posts: 403
Posted: December 10, 2014 at 11:22 PM / IP Logged
I originally used the dome light but the dome light kicked back on when the vehicle shut down after the MT takeover/shutdown procedure
It a crime stopper RS4-G4
pts760
Copper - Posts: 403
Posted: December 10, 2014 at 11:25 PM / IP Logged
Edit: I meant after reservation mode
Friday, July 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
