2015 GMC Stand Alone, EVO-GMT3
ziggyb222
Silver - Posts: 593
Posted: March 09, 2015 at 8:20 AM / IP Logged Link to Post Post Reply Quote ziggyb222
Anyone out there with any experience doing a GMC Sierra 2015 with the EVO-GMT3. Any help would be great!!!!!!
tedmond
Gold - Posts: 4,610
Posted: March 09, 2015 at 11:50 AM / IP Logged Link to Post Post Reply Quote tedmond
Haven't used the stand alone, but have done a loaded compustar + blade. You have to hardwire locks if it doesn't have on-star. other than that pretty straight forward.
Ted
Compustar Expert
ziggyb222
Silver - Posts: 593
Posted: March 09, 2015 at 2:56 PM / IP Logged Link to Post Post Reply Quote ziggyb222
Did you use the lt GREEN/ grey parking light wire in the white plug at the BCM???The Stand Alone is very easy to do...just had a issue with the parking lights..
tedmond
Gold - Posts: 4,610
Posted: March 09, 2015 at 5:11 PM / IP Logged Link to Post Post Reply Quote tedmond
Yes i did. whats the parking light issue? if you're getting headlight flashes randomly, i've encountered it before as well
Ted
Compustar Expert
ziggyb222
Silver - Posts: 593
Posted: March 09, 2015 at 9:07 PM / IP Logged Link to Post Post Reply Quote ziggyb222
I am a little confused... In auto the lt GREEN/ grey wire shows 12 volts..when I turn on the switch for park lights...just the parklights come on..but that wire still shows 12 volts...shouldnt that show 0 after the lights are on???
tedmond
Gold - Posts: 4,610
Posted: March 09, 2015 at 11:49 PM / IP Logged Link to Post Post Reply Quote tedmond
it's a low current negative. how are you testing?
Ted
Compustar Expert
ziggyb222
Silver - Posts: 593
Posted: March 10, 2015 at 6:03 AM / IP Logged Link to Post Post Reply Quote ziggyb222
With my meter... It didnt seem when I switched the parklights on..it changed..now if I turn the switch all the way to the left...like to turn off the Auto lights...the voltage dropped to zero...
tedmond
Gold - Posts: 4,610
Posted: March 10, 2015 at 9:02 AM / IP Logged Link to Post Post Reply Quote tedmond
parking lights can also be grey same plug. Red to constant, black to parking wire. should show 12 on meter
Ted
Compustar Expert
ziggyb222
Silver - Posts: 593
Posted: March 10, 2015 at 7:51 PM / IP Logged Link to Post Post Reply Quote ziggyb222
Okay thanks!!! My buddies truck...3X to start works great...T-Harness to the Evo All and then lock,unlock,parklights and I use the Valet switch and hood pin...Super easy at the BCM...I will get the truck this weekend... Thanks for the help!!!!
Friday, May 17, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
