200ma to 500ma
Scrapin 240
Posted: May 22, 2003 at 5:50 PM / IP Logged
How can I get a 200MA output up to 500ma?
Thanks in Advance
cool_greg
Copper - Posts: 125
Posted: May 22, 2003 at 6:16 PM / IP Logged
Drive a relay with the output
Greg
Scrapin 240
Posted: May 22, 2003 at 6:54 PM / IP Logged
how would i set that up or what type of relay would i use
JWorm
Platinum - Posts: 2,208
Posted: May 22, 2003 at 7:37 PM / IP Logged
86 - constant fused +12v
85 - (-) trigger from alarm
30 - output to whatever you are trying to activate
87 - either constant fused +12v or ground depending on what you want the output to be.
jasonhko
Member - Posts: 6
Posted: May 23, 2003 at 11:23 PM / IP Logged
I got a window module sitting around that ive been wanting to install. It requires 500mA ground when armed, this means that I would do..
85 - 200mA trigger from alarm
30 - 500mA wire to window module
87 - ?????
Platinum - Posts: 12,488
Posted: May 23, 2003 at 11:28 PM / IP Logged
If you have a window module all you have to do is hook up the window module's trigger wire to the alarms's AUX output wire. Hook up the power and the ground and the appropriate wires for up or down.
jasonhko
Member - Posts: 6
Posted: May 23, 2003 at 11:35 PM / IP Logged
there is the problem. My alarm doesn't have any 500mA outputs. They are all 200mA. Its a stupid CompuSTAR from like 3 years ago. The instructions from that told me specifically that all outputs are 200mA.
jasonhko
Member - Posts: 6
Posted: May 24, 2003 at 1:17 AM / IP Logged
update: Figured it out.
86 = +12v constant
85 = 200mA trigger from alarm
30 = 500mA input of window module
87 = ground.
jasonhko
Member - Posts: 6
Posted: May 24, 2003 at 12:55 PM / IP Logged
ok.. kinda worked.. when i try and use the module, it rolls the windows up a little bit then stops. then if I push the button again, it rolls it up again and then stops. I think im not getting a constant (-)500mA ground. Any help please/.
Posted: May 24, 2003 at 4:23 PM / IP Logged
Does the unit allow you to program the AUX channel from pulsed to constant ?
