warm relay
adamd
Posted: May 24, 2003 at 8:11 PM / IP Logged
guys; is it normal when a relay gets warm? just put a 30a-40a relay in my fuel pump line.while doing this i let the engine run for a while, and noticed it got warm.could the installation be wrong or the relay? should i upgrade the wiring to a 14 gauge?
auex
Platinum - Posts: 5,041
Posted: May 25, 2003 at 7:31 PM / IP Logged
Relays will get warm if they are used constantly. Being that it is your fuel pump you should probably upgrade the wires anyways.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
adamd
Posted: May 26, 2003 at 1:21 AM / IP Logged
thanks
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
