tacoma autolights rs
do58
Member - Posts: 9
Posted: September 28, 2015 at 2:46 PM / IP Logged Link to Post Post Reply Quote do58
hello, pretty new to installing and new to the forum (hope not breaking any rules so far). trying to do a viper remote start and done and all works well except that the daytime rights stay on until I open the drivers door. can someone please inform me on the proper way of making it to where when the motor shuts down via remote or times out the shut off on there own? or direct me to a link/thread if already explained. not wanting to duplicate and sorry if I did.
thank you
Mark Mizenko
Copper - Posts: 460
Posted: September 28, 2015 at 8:16 PM / IP Logged Link to Post Post Reply Quote Mark Mizenko
What year Tacoma? You can pulse the door trigger (probably need a relay) with the Fact alarm rearm wire, or hit the auto lamp wire, might need a relay (what year?)
do58
Member - Posts: 9
Posted: September 29, 2015 at 8:06 AM / IP Logged Link to Post Post Reply Quote do58
2014.... Viper rs....no have heard that people use the GREEN / WHITE to the door trigger. If so, do you need a diode? If using a relay would you wire it like 85 gn/wh 86 12vt 87 ground 30 - trigger? Or if use auto light wire 85 gn/wh 86 12vt 87a 1 side wire 30 other side? Please correct me if wrong. Relays not my strongest now. Trying to get them down
Mark Mizenko
Copper - Posts: 460
Posted: September 29, 2015 at 11:00 PM / IP Logged Link to Post Post Reply Quote Mark Mizenko
If the wire needs to be opened, yep. You got em both right.
No you won't need a diode, it that's all you're connecting.
Some vehicles don't need a relay for door pin shutdown method, but Toyota does.
Sunday, September 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
