Remote start 2008 honda civic
obeynation
Member - Posts: 17
Posted: October 11, 2015 at 3:38 PM / IP Logged Link to Post Post Reply Quote obeynation
Hey all , I just installed a viber 2 way and a dball in my 08 civic , everything's working great only problem is why can't I open or lock the doors using the viber remote while the car is on ? I'm using d2d is there any way around this any help would be greatly appreciated thank you !
Posted: October 11, 2015 at 5:29 PM / IP Logged Link to Post Post Reply Quote howie ll
Did you wire lock/unlock from the viper or from the DB-ALL 2?
obeynation
Member - Posts: 17
Posted: October 11, 2015 at 10:38 PM / IP Logged Link to Post Post Reply Quote obeynation
I wired it to the DB-ALL
Posted: October 11, 2015 at 11:48 PM / IP Logged Link to Post Post Reply Quote howie ll
Pink at ignition switch, test, it should go to ground when the key is inserted.
Join that to the dark blue status output wire on the Viper H2 plug.
obeynation
Member - Posts: 17
Posted: October 13, 2015 at 5:36 PM / IP Logged Link to Post Post Reply Quote obeynation
I have joined the dark blue status output wire to the pink pin 1 key sense wire on the green ignition switch and this hasn't solved the issue , should I remove it ? Is there a way I can wire the unlock and lock to the viper instead of it going thru dball ? And still keep it d2d? This is my first remote start install so sorry for any of the " noobness" thank you for all the replies so far !
Posted: October 13, 2015 at 5:43 PM / IP Logged Link to Post Post Reply Quote howie ll
I've always done them with lock and unlock from the DB-ALL, don't worry about the pink it obviously makes no difference.
did you use a DBN-ALL or a DB-ALL 2?
obeynation
Member - Posts: 17
Posted: October 13, 2015 at 6:23 PM / IP Logged Link to Post Post Reply Quote obeynation
I have used a DB-ALL , Its programmed to the default settings , maybe we're I wired the unlock and lock wires is the problem ? I wired them to that harness that on the drivers side kick panel i found the green and grey wire there, is there an alternative place for the wiring ? I appreciate the quick response !
obeynation
Member - Posts: 17
Posted: October 13, 2015 at 6:25 PM / IP Logged Link to Post Post Reply Quote obeynation
It's also just the DB-ALL NOT THE new DB-ALL2 version
Posted: October 13, 2015 at 6:26 PM / IP Logged Link to Post Post Reply Quote howie ll
No that's correct but I'm worried that the older DB-ALL may not be compatible.
You'd have to contact DEI for an answer.
obeynation
Member - Posts: 17
Posted: October 13, 2015 at 7:46 PM / IP Logged Link to Post Post Reply Quote obeynation
Well it unlocks and locks the doors it just doesn't do it while the engine is on . I was told maybe I should try to connect it via the viper instead ?
Page of 3
Thursday, September 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
