Tach wire and Horn wire on 2001 I30 Infiniti.
smiley10
Posted: October 28, 2015 at 11:20 AM / IP Logged Link to Post Post Reply Quote smiley10
I have a 2001 and a 2000 I30 infiniti with 3.0 V6"s. I pulled the Remote Start Pursuit 9775T out of the 2000 and installed it on the 2001. My issue is finding the tach wire. Although I have located what is supposed to be the right wire (same color code, same approx. ecm location) I don't see enough AC voltage with my DVM on it. The unit is not sensing that wire during tach programming. The wire is at White w Green Tracer on both vehicles at the ECM plug. The unit worked fine in the 2000. Does anyone know or have a different target wire at the ECM. I tried reading one of the coils at the engine and I got only 10 -20 millivolts there also. It has been my experience that I will usually get 1-4 volts, on idle to light throttle position. I also could not find the horn trigger wire at the column either. Would appreciate any help. I have a Directed Electronics and an Omega wiring guide sheet that I used to find everything else. Thanks.
Posted: October 28, 2015 at 12:20 PM / IP Logged Link to Post Post Reply Quote howie ll
OBD pin 9 for tach alternatively look for a black junction box in the engine bay, drive side by strut. It's the igniter wire routing, open it and you might find one wire in a loop, join after testing.
I've always found OEM in Toyotas in the steering column loom, good old Snap-On bulb tester is perfect for finding it.
Horn is GREEN / WHITE where I said.
smiley10
Posted: October 28, 2015 at 1:22 PM / IP Logged Link to Post Post Reply Quote smiley10
I Don't know why I didn't think of the OBD for the tach. I have the alarm manuals, wiresheets for target wires (as stated in my post), test equipment. Except for this forum, I used all of them before posting. I'm not a rookie, I just haven't done installs since 1990. I'm not offended though, this is the first time I have had to ask for anything. I do appreciate your leads for the tach wire. Have a great day.
Posted: October 28, 2015 at 1:27 PM / IP Logged Link to Post Post Reply Quote howie ll
No problems, listen I'm semi-retired now, been out of day to day work for 10 months, the basic knowledge is still there but it takes me twice as long to think it through.
smiley10
Posted: October 28, 2015 at 7:18 PM / IP Logged Link to Post Post Reply Quote smiley10
I hear ya. Same for me. At 52, Only doin my own vehicles. Still have those issues, but I'll figure it out.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
