Viper 4105V installation issues
mickey53usa
Posted: January 14, 2016 at 12:28 PM / IP Logged Link to Post Post Reply Quote mickey53usa
I am fortunate to find this thread. I have looked at this site for a while, now I found what I am looking for.
2005 Jeep Wrangler - No Sentry Key, No immobilizer, no power door locks - yet.
Question 1- on the door lock wires from the 4105v control unit. Since I am adding two wire door lock actuators, does the 4105v controller have a built in relay so I can connect green from controller to green to actuator and blue from controller to blue from actuator? If there is no relay in the controller, I have no problem adding a couple (one for green, one for blue). Just did not want to complicate things.
Question 2- I see no indication the the remote start part of the system requires a "pass through" on any of the connections. It appears from what I have found that these are all "tap" connections. Is this correct.
Wiring will be very similar to the OP, with the exception of the door locks.
TIA
Michael, TX
Posted: January 14, 2016 at 12:34 PM / IP Logged Link to Post Post Reply Quote howie ll
You will need a 451 module that plugs into your lock port else if the locking kit has a dedicated timer relay then those wires are fine.
What do you mean by pass through?
And when you say TAP I hope you mean soldered joints.
mickey53usa
Posted: January 20, 2016 at 4:44 PM / IP Logged Link to Post Post Reply Quote mickey53usa
Thanks for the reply -
By "TAP" I mean a soldered connection.
By "pass through" I mean a wire in the ignition harness cut, connected to a wire that goes through the controller and the free end of the "cut wire" connected to another wire coming from the controller.
Got the relays for the door locks figured out - using two five pole (Bosch style) relays. One connected to the blue lock wires, one to the green lock wires -
Michael, TX
Posted: January 20, 2016 at 4:47 PM / IP Logged Link to Post Post Reply Quote howie ll
Then you are quite correct, no "pass through".
