2007 Peugeot 308 Lock Trigger
tafarelli
Copper - Posts: 55
Posted: January 09, 2016 at 9:34 AM / IP Logged
ok
dk
tafarelli
Copper - Posts: 55
Posted: January 09, 2016 at 10:06 AM / IP Logged
I used zeners to connwct lock and unlock signal from pke. Is that ok?
dk
tafarelli
Copper - Posts: 55
Posted: January 09, 2016 at 10:16 AM / IP Logged
I consulted manual and I have two options. I can connect to two wires one of which controls both left side lights and other both right side lights. Also I can connect to 4 wires which control them separately. Is it all the same or should I go by 4 wires connect as you suggested (2 wires connect is obviously easier)?
dk
Posted: January 09, 2016 at 10:18 AM / IP Logged
4 separate with the diodes.
tafarelli
Copper - Posts: 55
Posted: January 09, 2016 at 10:19 AM / IP Logged
ok
dk
Posted: January 09, 2016 at 10:20 AM / IP Logged
The zeners are OK, 100mA or less on those triggers.
tafarelli
Copper - Posts: 55
Posted: January 09, 2016 at 11:42 AM / IP Logged
K
dk
tafarelli
Copper - Posts: 55
Posted: January 09, 2016 at 1:47 PM / IP Logged
Any idea on how to turn of beeping sound when opening door because key is in the lock(without cutting main door info trigger, which is pin 4 on white 40 way bsi and not 27, all other pin numbers you were right)?
dk
tafarelli
Copper - Posts: 55
Posted: January 09, 2016 at 4:10 PM / IP Logged
Maybe it can be turned off via computer software connected through obd2 interface?
dk
tafarelli
Copper - Posts: 55
Posted: January 10, 2016 at 8:42 AM / IP Logged
Its ok I can live with it:)
I have located and tested all wires left:4 blinkers, 4 door triggers, hand brake and fuel gauge. Car is also remote starting:)
Tomorrow I will connect with diodes and install is finally complete yuppie...
M8 tx 4 everything if you would give me your paypal email address please I would like to buy you a beer or two:)
dk
Page of 10
