Heated seats on with remote start
meanwire
Member - Posts: 18
Posted: January 13, 2016 at 10:25 PM / IP Logged Link to Post Post Reply Quote meanwire
Want heated seats to come on when starting truck with remote start.
So I've got an aftermarket remote start installed in my 2008 Ford Super Duty Power Stroke diesel truck. I asked to have my heated seats turn on when I remote start the truck, they said it can't be done. Surely there's a way to do it. Has anybody been able to do this successfully if so how did you do it. Thank you!
mscguy
Copper - Posts: 212
Posted: January 13, 2016 at 10:43 PM / IP Logged Link to Post Post Reply Quote mscguy
What aftermarket starter do you have?
meanwire
Member - Posts: 18
Posted: January 13, 2016 at 11:36 PM / IP Logged Link to Post Post Reply Quote meanwire
I have a Compustar Slice and using Compustar Mobile Drone app on iPhone.
mscguy
Copper - Posts: 212
Posted: January 14, 2016 at 12:01 AM / IP Logged Link to Post Post Reply Quote mscguy
Was it the original install company that said you couldn't do it?
I would assume whoever did it originally had the ability to program your control module. If not, I suggest taking it somewhere who can.
Otherwise, you could attempt to wire it yourself, then take it somewhere for programming.
Do you know what control module you have? The slice is just the remote Kit.
meanwire
Member - Posts: 18
Posted: January 14, 2016 at 11:21 AM / IP Logged Link to Post Post Reply Quote meanwire
Yes it was the original install company that told me it couldn't be done cause they have had problems in the past. They are a good reputable shop, surprised they couldn't do it. The control module they used is Compustar 6200S Controller(DT) Model: FT6200S-CONT
geepherder
Platinum - Posts: 3,668
Posted: January 14, 2016 at 3:49 PM / IP Logged Link to Post Post Reply Quote geepherder
If your system has a rear defrost output, maybe you could use this to trigger a relay. Otherwise, a ground-while-running wire might be used. I'm not familiar with Compustar. Just test the wires at the switch, and program accordingly.
mscguy
Copper - Posts: 212
Posted: January 14, 2016 at 3:53 PM / IP Logged Link to Post Post Reply Quote mscguy
Maybe there is something with your truck's particular wiring that they didn't want to do it. Looking at a diagram, it doesn't look special. Just programming a couple POC to aux outs, and connecting them.
Is it still under warranty with them? If not, maybe try somewhere else.
Friday, March 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
