93 Altima power window amplifier workaround
robbiewilso
Posted: February 07, 2016 at 5:26 PM / IP Logged Link to Post Post Reply Quote robbiewilso
After some research I have found that I have bad "amplifiers" for my power windows on my 93 Altima. I have found replacements but at over $100 each they are cost prohibitive. Evidently the amplifier is an electronic relay. I have traced the wiring back and have id'd the power window motor wires, the main power wires, and the wires going to the window up/down switch. The window switch provides continuity to the "amplifier" to 2 different wires when the switch is pressed in the up and down direction, and uses a common wire to complete continuity. My question is: how to duplicate the function of the amplifier using 12v relays or other tricks. Thanks to any who reads this and understands my needs, and has solutions! Thanks!
RoBBiE WiLsO
geepherder
Platinum - Posts: 3,668
Posted: February 07, 2016 at 7:04 PM / IP Logged Link to Post Post Reply Quote geepherder
Sounds similar to a 5-wire door lock application: https://www.the12volt.com/doorlocks/page3.asp#5w
mscguy
Copper - Posts: 212
Posted: February 07, 2016 at 8:26 PM / IP Logged Link to Post Post Reply Quote mscguy
Could you do what this guy did?
http://www.240sxforums.com/forums/general-tech/146617-how-fix-your-power-windows-ditch-amp.html
Not an altima, but still a Nissan. Same principle.
Also, yes, similar to a 5 wire door lock as per Geep's post.
robbiewilso
Posted: February 08, 2016 at 6:03 AM / IP Logged Link to Post Post Reply Quote robbiewilso
Yes I scoured the web and found the post you mention. His application is similar and gave me some ideas. I was just hoping I could find someone who had the exact application and devised a workaround and I could just clone their system. I'm lazy :) and not the genius at wiring I think I am.
RoBBiE WiLsO
Sunday, July 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
