Correct install of two 12 subs in sealed enclosure
Welcome Guest :)
hyzzle
Member -
Posted: February 19, 2016 at 12:50 PM / IP Logged
I'm just wondering the correct way to install 2 12"infinity reference 1262w dvc in a sealed box? They came with some cushioning tape like stuff and I'm not sure what to do with that
DYohn
Moderator -
Posted: February 20, 2016 at 8:47 AM / IP Logged
Are you talking about how to mount the drivers to the enclosure? Yes, using weather strip tape is one way to seal the driver frame to the enclosure. I like to use pliable gasket material like this:
Parts Express caulk And then screw the driver to the front baffle.
hyzzle
Member -
Posted: February 20, 2016 at 9:55 AM / IP Logged
How does the weather strip make a seal with a carpeted enclosure?
DYohn
Moderator -
Posted: February 20, 2016 at 1:57 PM / IP Logged
hyzzle wrote:
How does the weather strip make a seal with a carpeted enclosure? |
Stick to back of woofer frame with foam side toward enclosure. Screw down. Is it a perfect seal? No. Will it matter? Sounds like you are using a prefab enclosure, so no.
If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum
Tuesday, August 19, 2025
• Copyright © 1999-2025 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
