3 issues with Viper 4105V+GMDLBP-'03 Silverado
gttj
Posted: February 28, 2016 at 5:36 PM / IP Logged Link to Post Post Reply Quote gttj
I installed a Viper 4105V with the GMDLBP in my '03 Chevy Silverado. After troubleshooting a couple issues, I've still got a couple that I can't figure out.
1) Most of the time I can't lock the vehicle with the lock button on the remote. If I hold the lock button down the panic goes off so I know the button and receiver are working. If I double tap the unlock button on the remote, the vehicle with lock. Every once and awhile it will work but I can't track the steps that gets it to work and repeat them.
2) If I've locked the truck from the button on the door or with the key from the outside and then try to use the unlock button on the remote, the doors will unlock but then lock back ~3 seconds later.
3) The remote start function works but if I push the brake pedal without the key installed, the vehicle doesn't shutdown. I've got the brown wire connected to the white wire at the brake pedal.
Thanks in advance for your thoughts on troubleshooting....
smokeman1
Platinum - Posts: 1,589
Posted: February 29, 2016 at 3:05 PM / IP Logged Link to Post Post Reply Quote smokeman1
Is the GMDLBP set to type 4? and locked in.
Are the connections soldered?
Violet wire should have been the last wire connected.
Are all the connectors in tight? No bent pins?
