2015 Nissan Altima Alarm/Remote Start/Stereo Wiring
nsboudreaux29
Posted: July 18, 2016 at 9:08 AM / IP Logged
I have a 2015 Nissan Altima SV with small non touchscreen radio. wiring is currently 3 different white plugs (20-pin, 24-pin, 6-pin), I am trying to upgrade to the OEM navigation unit which only has 2 (20-pin) White plugs. I really need both wiring diagrams for each radio. Thank you
nsboudreaux29
Posted: July 18, 2016 at 10:26 AM / IP Logged
I made a mistake in the original post. Current non touchscreen radio has 3 white plugs, (20-pin, 32-pin, and 8-pin). The navigation radio I am trying to swap to has 2 white plugs (existing 20-pin, and a 24-pin)
tonanzith
Gold - Posts: 593
Posted: July 18, 2016 at 9:02 PM / IP Logged
2015 Nissan Altima (Smart Key) - North America     DirectWire Vehicle Information
All Products
Item     Wire Color     Polarity     Wire Location
12 Volts     white (40A)     +     BCM behind instrument cluster, white 15 pin plug, pin 11
Second 12 Volts     green (40A)     +     dash fuse box, rear, white 1 pin plug, pin 1
Starter     brown     -     BCM behind instrument cluster, black 40 pin plug, pin 22
Second Starter     red (push-button start)     -     push-button ign sw or BCM behind instr cluster, grn 40 pin plug, pin 1
Ignition     white     +     BCM behind instrument cluster, black 40 pin plug, pin 27
Second Ignition     green     -     BCM behind instrument cluster, black 40 pin plug, pin 30
Accessory     red     +     BCM behind instrument cluster, black 40 pin plug, pin 26
Second Accessory     pink     +     BCM behind instrument cluster, black 24 pin plug, pin 9
Data Bus     (NATS antenna is on the push-button ignition sw)
CAN Bus High     blue     data     data link conn or BCM behind instr cluster, black 40 pin plug, pin 20
The security light is green (-) at the BCM behind instrument cluster, green 40 pin plug, pin 18.
CAN Bus Low     pink     data     data link conn or BCM behind instr cluster, black 40 pin plug, pin 19
Power Lock     green (with LF only anti-pinch window)     -     BCM behind instrument cluster, green 40 pin plug, pin 19
On models with LF and RF anti-pinch windows, use the factory alarm arm.
Power Unlock     beige (with LF only anti-pinch window)     -     BCM behind instrument cluster, green 40 pin plug, pin 34
On models with LF and RF anti-pinch windows, use the factory alarm disarm.
Lock Motor     brown     5 wire     BCM behind instrument cluster, white 15 pin plug, pin 7
Driver Unlock Motor     purple     5 wire     BCM behind instrument cluster, white 15 pin plug, pin 9
Passenger Unlock Motor     lt. blue     5 wire     BCM behind instrument cluster, white 15 pin plug, pin 2
Factory Alarm Arm     pink (with LF only anti-pinch window) (key lock)     -     BCM behind instrument cluster, black 40 pin plug, pin 34
On models with LF and RF anti-pinch windows, it is pink (-) at the power window main switch, white 16 pin plug, pin 3.
Factory Alarm Disarm     green (with LF only anti-pinch window)(key unlock)     double -     BCM behind instrument cluster, green 40 pin plug, pin 24
On models with LF and RF anti-pinch windows, it is green (double -) at the power window main switch, white 16 pin plug, pin 15.
Disarm No Unlock     (see factory alarm disarm)
Parking Lights (+)     red     +     dash fuse box, brown 16 pin plug, pin 1
Hazards     yellow     -     BCM behind instrument cluster, green 40 pin plug, pin 36
Turn Signal (Left)     lt. blue (F); yellow (R)     +     BCM behind instr cluster, bk 24 pin plg, pin 13; gry 24 pin plg, pin 23
Turn Signal (Right)     brown (F); lt. green (R)     +     BCM behind instr cluster, bk 24 pin plg, pin 1; gry 24 pin plg, pin 12
Headlight     pink (L), red (R) (LO); yellow (L), blue (R) (HI)     +     underhood fuse box, white 8 pin plug, pins 3, 2; 8, 7
Reverse Light     brown     +     BCM behind instrument cluster, gray 24 pin plug, pin 24
Left Front Door Trigger     brown     -     BCM behind instrument cluster, gray 24 pin plug, pin 16
Right Front Door Trigger     lt. blue     -     BCM behind instr cluster, gray 24 pin plug, pin 14
Left Rear Door Trigger     yellow     -     BCM behind instr cluster, gray 24 pin plug, pin 2
Right Rear Door Trigger     purple     -     BCM behind instr cluster, gray 24 pin plug, pin 13
Dome Supervision     pink     -     BCM behind instrument cluster, white 15 pin plug, pin 8
Trunk/Hatch Pin     lt. blue     -     BCM behind instrument cluster, gray 24 pin plug, pin 17
Hood Pin     yellow     -     underhood fuse box, white 16 pin plug, pin 15
Trunk/Hatch Release     brown     -     release sw or BCM behind instr cluster, black 40 pin plug, pin 40
Trunk Release Motor     purple     5 wire     BCM behind instrument cluster, gray 24 pin plug, pin 11
Tachometer     brown or yellow (I4); yellow (V6)     ac     any fuel injector, gray 2 pin plug, pin 2
Fuel Pump     red     +     driver kick, white 12 pin plug, pin 5
Rear Defroster     yellow     - latched     BCM behind instrument cluster, black 40 pin plug, pin 21
Mirror Defroster     (same as rear defroster)
Left Front Heated Seat     lt. green     5 wire     left front heated seat switch, white 6 pin plug, pin 5
Right Front Heated Seat     brown     5 wire     right front heated seat switch, brown 6 pin plug, pin 5
Speed Sense     green     8-Pulse     radio, white 20 pin plug, pin 18
Brake Wire     green     +     BCM behind instrument cluster, green 40 pin plug, pin 27
Parking Brake     lt. green to green     -     parking brake switch or driver kick, white 100 pin plug, pin 12
Horn Trigger     green     -     horn switch, yel 6 pin plg, pin 3 or driver kick, wht 100 pin plg, pin 35
Wipers     yellow (LO); blue (HI)     +     underhood fuse box, white 12 pin plug, pins 5, 12
Left Front Window (Up/Down)     white - red (with LF only anti-pinch window)     A     power window main switch, white 3 pin plug, pins 1 - 3
On models with LF and RF anti-pinch windows, use the factory alarm arm/disarm to roll the windows up/down.
Right Front Window (Up/Down)     yellow - purple (with LF only anti-pinch window)     A     driver kick, door harness, white 16 pin plug, pins 1 - 2
Left Rear Window (Up/Down)     lt. blue - yellow     A     driver kick, door harness, white 16 pin plug, pins 12 - 13
Right Rear Window (Up/Down)     brown - purple     A     driver kick, door harness, white 16 pin plug, pins 14 - 15
Sun Roof (Open/Close)     blue - green (function with ignition on only)     -     moonroof switch, white 12 pin plug, pins 4 - 9
Radio 12V     green     +     radio, white 20 pin plug, pin 19
Radio Ground     (chassis on base audio); gray (except base audio)     -     radio, white 20 pin plug, pin 20
Radio Ignition     pink     +     radio, white 20 pin plug, pin 7
Radio Illumination     red     +     radio, white 20 pin plug, pin 9
Factory Amp Turn-on     white     +     radio, white 20 pin plug, pin 1
Power Antenna     black     +     radio, gray 3 pin plug, pin 1
Left Front Speaker (+/-)     purple - lt. blue or black - white     +,-     radio, white 20 pin plug, pins 2 - 3
On models with amplifier, the speaker wires are pink - red at the amplifier under rear deck, brown 14 pin plug, pins 9 - 10.
Right Front Speaker (+/-)     yellow - brown or black - white     +,-     radio, white 20 pin plug, pins 11 - 12
On models with amplifier, the speaker wires are pink - beige at the amplifier under rear deck, brown 14 pin plug, pins 13 - 4.
Left Rear Speaker (+/-)     brown - yellow or green - red     +,-     radio, white 20 pin plug, pins 4 - 5
On models with amplifier, the door speaker wires are green - white at the amplifier under rear deck, brown 23 pin plug, pins 11 - 1.
Right Rear Speaker (+/-)     lt. green - purple or green - red     +,-     radio, white 20 pin plug, pins 13 - 14
On models with amplifier, the door speaker wires are green - white at the amplifier under rear deck, brown 23 pin plug, pins 10 - 23.
Center Channel (+/-)     green - red     +,-     amplifier under rear deck, brown 14 pin plug, pins 11 - 12
Subwoofer (+/-)     wht - grn (L); wht - grn (R) (rear deck skr w/amp)     +,-     amplifier under rear deck, brown 14 pin plug, pins 6 - 1; 7 - 8
Aux. Audio Input Left (+/-)     red - black     +,-     radio, wh 8P plg, pins 4-2 or wh 24P plg, pins 3-2
Aux. Audio Input Right (+/-)     white - black     +,-     radio, wh 8P plg, pins 3-2 or wh 24P plg, pins 1-2
RSE Video (+/-)     black - (shield) (rear view camera video)     +,-     radio, wh 32P plg, pins 2-1; wh 24P plg, pins21-22
Satellite Radio 12 Volts     (built into radio)
Item     Size     Depth     Location
Headunit     irregular center of dash
Left Front Speaker   left front door
Left Front Tweeter   left front dash
Right Front Speaker   right front door
Right Front Tweeter   right front dash
Left Rear Speaker   left rear deck (w/o amp); rear door (w/amp)
Right Rear Speaker   right rear deck (w/o amp); rear door (w/amp)
Center Channel   top center of dash
Subwoofer   left and right rear deck (with amp)
Satellite Radio Tuner     (built into radio)
Gary Sather
greyscout
Posted: November 06, 2017 at 11:03 AM / IP Logged
This was very helpful yesterday. My brother-in-law wanted me to hook up new speakers and a sub in his 2017 Altima. I had to dope out the head unit because he wanted to maintain functionality with it. It's been a while since I've installed a system, but we got it to work via high/low converter. Problem is, it won't turn off now. I hooked up the remote leads for the amps and line converter to what is labeled as the "pink radio ignition" wire. Can this not be used as a remote turn-on lead? Was I supposed to splice into something else? Any help would be much appreciated.
rs specialist
Copper - Posts: 175
Posted: November 16, 2017 at 5:08 PM / IP Logged
What equipment is installed, some audio equipment has auto sense which will turn on the amp when there is a signal on the RCA, Make sure you list the converter also.
greyscout
Posted: November 16, 2017 at 5:40 PM / IP Logged
I don't have the specifics. All I remember is that the sub amp is Fosgate Power, the speaker amp is Alpine, and the converter is off-brand. All of these parts were once in my vehicle and functioned as if they did not have a signal sensor to turn on. Does the pink ignition wire supply a constant 12v charge? I thought about using the "factory amp turn-on (white)" wire, but didn't see one. Maybe I overlooked it, but I guess that would make the most sense to use? Thanks for the reply, btw.
Friday, December 1, 2023 • Copyright © 1999-2023 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
