DEI Glass Break Sensor disables Warn Away
street tuner 9
Member - Posts: 13
Posted: May 29, 2003 at 11:28 PM / IP Logged
I installed a Viper 790XV with 2 shock sensors, a proximity sensor, and a DEI Glass Break Sensor. When the microphone is plugged into the GB sensor, the Warn Away response no longer works. The alarm will trigger immediately. This applies to all sensors. However, if the microphone is unplugged, the Warn Away response is restored. I have the GB sensor soldered with one of the shock sensors as per DEI instructions. I have adjusted sensitivity on all sensors. Still the same problem. Any help would be appreciated!
auex
Platinum - Posts: 5,041
Posted: May 30, 2003 at 5:07 PM / IP Logged
Did you use diodes to isolate the sensors?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
djfearny2
Silver - Posts: 810
Posted: May 30, 2003 at 5:21 PM / IP Logged
must use diodes and on the blue and or green wire from shock sensors and stuff . all this for one car is a little much........... but anyways you have to isolate all the sensors from one another. and it would be better if you gave the black wire of each a ground other than the black wire on the original shock senosr. so the only wire that should be getting ground from alarm should be the first shock sensor..,.
Jon
Installer/Help Technician
---coral springs florida---
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
