APS997E in 99 honda civic no power locks
arg auto
Posted: December 17, 2016 at 8:21 PM / IP Logged Link to Post Post Reply Quote arg auto
I have a 99 Honda civic when I remote start it the starter juss clicks and alarm goes off.
zzzz
lectricguy
Copper - Posts: 359
Posted: December 18, 2016 at 9:22 AM / IP Logged Link to Post Post Reply Quote lectricguy
Sounds like the car battery is dead...I would bet it is tough to start with the key also. When the 997E loses power (drops during start because the battery is too weak), the alarm will go off when the voltage returns to normal after crank attempt.
Turn the ignition to ON with the key, and press and hold the programming button on the antenna until the antenna light illuminates. This will disable the alarm temporarily while you fix your battery issue.
Once you fix the issue, repeat those steps==turn the ignition to ON with the key, and press and hold the programming button on the antenna until the antenna light turns off.
Hope this helps.
Lectric Guy
Wednesday, August 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
