Battery Charger Repair
firedemonsic
Member - Posts: 23
Posted: December 29, 2016 at 4:56 PM / IP Logged Link to Post Post Reply Quote firedemonsic
Got a 2/12/75 amp battery charger/jump starter from work for free. Customer stated it wasn't charging properly. Return label said to throw in trash.
Doesn't look like it's had much use. Either that or it was well cared for. Have not tried the jump start setting. On the 2 amp trickle charge mode it seems to function normally. When put on 12 amp rapid charge, the transformer can be heard cycling on and off and the output voltage bounces back and forth, along with the charge level indicator.
Also FWIW, for some reason, the red "POWER ON" LED on the front never illuminates.
I'm going to open it up and inspect. Any ideas where I should start looking?
This is the exact charger I have. Many thanks in advance.
http://partplace.com/products.php?q=AutoCraft+75+Amp+Engine+StartBattery+Charger+AC+750CRSE+127
Custom_Jim
Copper - Posts: 210
Posted: December 30, 2016 at 1:24 PM / IP Logged Link to Post Post Reply Quote Custom_Jim
I would take it apart and check for simple things like connections that might have come off or connectors that are not seated well. It might have been a thing to where originally it worked but got jarred and something came loose.
I would also look close for any burnt components, possible cold solder joints, and such.
Jim
1968 Chevy II Nova Garage Find 2012
1973 Nova Custom
1974 Spirit of America Nova
1973 Nova Pro-Street
