Viper 4706V w/dball2 in Mazda 2 2011
smokeman1
Platinum - Posts: 1,589
Posted: January 02, 2017 at 2:25 PM / IP Logged Link to Post Post Reply Quote smokeman1
If your Mazda is automatic transmission then the Viper needs to be put into automatic mode.
Menu 3, Item 1, Option 2, using the control center button and the remote.
Ignition on then off. press and hold the button until the horn chirps three times, or LED blinks three times, then release. press and release button 1 time, then press and hold. using the remote press the lock button.
That should put it into auto mode, release the button. wait 30 seconds for the system to exit the programming. Then try to program the DBALL.
waldbloc4
Member - Posts: 11
Posted: January 02, 2017 at 3:18 PM / IP Logged Link to Post Post Reply Quote waldbloc4
niiiiiiiice
thanks a million
you the best i'm all set. remote start and lock and unlock work as a charm. once i switched to automatic trans mode.
one more thing :))
i wanted to hook up the window since my mazda has driver roll/up/down window. on page 3 both lines shows in red. on the black pin they are h#4, h#5. i need to know where do i tie them up to the viper.
thanks again.
smokeman1
Posted: January 02, 2017 at 5:04 PM / IP Logged Link to Post Post Reply Quote smokeman1
Never done that but looks to me to be
24 Pin harness, Pin 7, WHITE/ Violet is AUX 1, and Pin 19, Violet/Black is AUX 2.
waldbloc4
Member - Posts: 11
Posted: January 02, 2017 at 6:15 PM / IP Logged Link to Post Post Reply Quote waldbloc4
the window roll/down didn't work after i tied the wires you mentioned. instead aux triggers to unlock doors.
windows thing is not a big deal at all to me.
I'm all good with the main option of remote start.
thanks again and nice chatting with you smokeman......
Peace...
waldbloc4
Member - Posts: 11
Posted: January 03, 2017 at 11:33 AM / IP Logged Link to Post Post Reply Quote waldbloc4
I'm looking to extend engine running time from 12 min on my viper4706v???
thanks.
smokeman1
Posted: January 03, 2017 at 7:39 PM / IP Logged Link to Post Post Reply Quote smokeman1
Same procedure as changing from manual to automatic, EXCEPT, it is Menu 3, Item 4, Option 2.
waldbloc4
Member - Posts: 11
Posted: January 03, 2017 at 7:55 PM / IP Logged Link to Post Post Reply Quote waldbloc4
nice.
thanks again
smokeman1
Posted: January 03, 2017 at 8:18 PM / IP Logged Link to Post Post Reply Quote smokeman1
https://www.the12volt.com/installbay/downloads.asp?srch=all&term=viper+quick
Quick Reference guide.
viiral
Posted: January 05, 2017 at 4:48 AM / IP Logged Link to Post Post Reply Quote viiral
Did you end up connecting anything else to the Aux harness or the viper?, im in the process of doing a 2011 mazda 2 but it is manual. Ill be posting a thread which includes the install process of my 4806 and ALCA.
waldbloc4
Member - Posts: 11
Posted: January 05, 2017 at 9:30 AM / IP Logged Link to Post Post Reply Quote waldbloc4
no
