2016 Chevy Volt Wiring Diagram
gafco
Member - Posts: 9
Posted: September 17, 2017 at 6:44 AM / IP Logged Link to Post Post Reply Quote gafco
I am looking for the wiring diagram for a 2016 Chevy Volt.Thanks.
Platinum - Posts: 13,726
Posted: September 17, 2017 at 12:31 PM / IP Logged Link to Post Post Reply Quote i am an idiot
For the entire car?
gafco
Member - Posts: 9
Posted: September 18, 2017 at 5:42 PM / IP Logged Link to Post Post Reply Quote gafco
For now I need to be able to have the onboard wifi to stay on for a period of time after key off.
Posted: September 18, 2017 at 8:21 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Does the radio stay powered up until you open the drivers door? Does the wi fi do the same? If so we may be able to disconnect the door trigger wire. If you di not open the door dies the radio turn off after 10 minutes?
Posted: September 19, 2017 at 8:25 AM / IP Logged Link to Post Post Reply Quote howie ll
Test for the WiFi power feed, if its IGN or ACC run a fused constant instead.
I have a mobile WiFi in my car, wired permanently doesn't draw enough juice to cause any problems.
