Friday, October 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Presently, you don't have to be an actual Dealer to have access to bypass module
firmware. You will need to get a FlashLink2 USB cable. They go for about $45. Fortin Tech Support is very
good and very friendly. While I'm sure there could be considerable debate on this subject, IMHO, for the
type of installs I do, both iDatalink and Fortin are better than XpressKit. Easier to follow Install Guides,
more reliable modules, better firmware. Bad situation but your options are limited. There is a slight learning
curve but you might be pleasantly surprised when you venture away from the snake pit...
