2007 Toyota Matrix Alarm
robert92
Member - Posts: 27
Posted: October 19, 2017 at 2:03 PM / IP Logged Link to Post Post Reply Quote robert92
Diagram I'm looking for my alarm to sound when dome lights are active.
Bypass option for the transpoder key
Proud owner of a Toyo Matrix
Posted: October 19, 2017 at 2:04 PM / IP Logged Link to Post Post Reply Quote howie ll
No plain orange. LOOK AT PAGE 4 of the INSTRUCTION MANUAL, I've given you the link above.
Posted: October 19, 2017 at 2:07 PM / IP Logged Link to Post Post Reply Quote howie ll
Green wire to connect to domelight, i.e. NEG door trigger, told you that already, you are going to get into so much trouble here, I've gone past any constructive help.
robert92
Member - Posts: 27
Posted: October 19, 2017 at 2:21 PM / IP Logged Link to Post Post Reply Quote robert92
So the orange wire, from the brain to the (-) turn on from the bypass, with the diodes. Should do the trick?
I apologise. I'm just having trouble understanding. I will do my best to figure this out with the information you have given. Thank you so much for your time!
Posted: October 19, 2017 at 4:08 PM / IP Logged Link to Post Post Reply Quote howie ll
I'm afraid with your lack of understanding we can't go any further.
I can't take any more responsibility for the damage you might do.
robert92
Member - Posts: 27
Posted: October 19, 2017 at 6:53 PM / IP Logged Link to Post Post Reply Quote robert92
I wouldn't hold anyone responsible but myself.
I purchased 4 of the 1n4004.
I will run the diagram for the bypass tomorrow.
As far as the red/yellow in the driver's pillar, is that corresponding to the door locks? That's my assumption. I believe I'm confused because we were posting a few things at a time.
I know I may seem frustrating, however can you walk me through what portion of the red/yellow you speak of and what its fuction is. This is the last I'll ask of you.
Again I have 4 1n4004's to put into the lines needed.
2 go to the by pass via the diagram. However the other two I was a bit perplexed about. The red/yellow wire goes to the door triggers?
If I can get the line out of the dome and ditch that I would happily place it in the triggers.
When I had the green (-) hooked into my driver's door trigger it did work. But I would like the (-) door trigger wire to attach to any door that would open.
Thank you.
Posted: October 20, 2017 at 1:18 AM / IP Logged Link to Post Post Reply Quote howie ll
Red/Yellow is the door trigger! That's what triggers the alarm when a door is opened and is connected to the green NEG door trigger wire.
robert92
Member - Posts: 27
Posted: October 20, 2017 at 8:19 AM / IP Logged Link to Post Post Reply Quote robert92
Okay that is what I thought, sorry for the confusion. So you stated earlier that I need to slpit the red/yellow door trigger wire place a 1n4004 in the line, then run another from the r/y to the keysense? Giving it a "y"
robert92
Member - Posts: 27
Posted: October 20, 2017 at 9:29 AM / IP Logged Link to Post Post Reply Quote robert92
Or green to red/yellow
And 1n4004 goes into the diagram for the bypass?
Posted: October 20, 2017 at 9:35 AM / IP Logged Link to Post Post Reply Quote howie ll
No! The orange by-pass wire is split using the diodes, one side to blue-black keysense, other side to by-pass.
Green NEG door trigger wire to red/yellow.
Page of 6
