2007 yukon with DB3 having issues with RXT
cokelly
Posted: October 23, 2017 at 4:06 PM / IP Logged Link to Post Post Reply Quote cokelly
Hello
I installed a DB3 with an XL202, 7765V remote and 6816T antenna. I have wired it just like the install guide says but after sitting for a few hours the viper remote won't work. The factory remotes work fine. I believe the vehicle is going into sleep mode. If I run the +12volt direct to another source will that solve my problem? Currently, all the wires go the OBd2 connector.
cokelly
Posted: October 23, 2017 at 9:10 PM / IP Logged Link to Post Post Reply Quote cokelly
One other solution I read was to run a negative output to the (-) door trigger. Would that mean to run the (-) RAP off out put to the (-) door trigger.
Can someone confirm this?
xxrzdxx
Member - Posts: 17
Posted: December 26, 2017 at 7:46 PM / IP Logged Link to Post Post Reply Quote xxrzdxx
Did you ever find a solution to your problem, I'm afraid I'm having the same problem.
