2013 Hyundai Tuscon Alarm/Remote Start Wiring
kaveh
Posted: November 20, 2017 at 2:46 PM / IP Logged
Hi,
I am trying to create a remote start for my Tucson. I have built the needed electrical board and programmed all the needed microcontrolers. Now I need the wiring diagram for my car so I could connect my board to it. Specificaly I need the wiring for the lock & unlock system and more important, the Engine Start-Stop Switch wiring diagram.
Any help would be appreciated.
kaveh
Posted: November 20, 2017 at 2:47 PM / IP Logged
Just in case, The car is:
Hyundai Tucson 2013 limited edition
wirewise
Moderator - Posts: 489
Posted: November 20, 2017 at 3:09 PM / IP Logged
TUCSON      2010-2016
KEY      T-HARNESS      IMMOBILIZER
N/A      N/A      TRANSPONDER TYPE REQUIRES BYPASS AND EXTRA KEY TO REMOTE START. VEHICLES 2015 AND UP AND VEHICLES WITH SMART KEY AND PUSH TO START REQUIRE A DBALL2 INTERFACE FOR REMOTE STARTING
PART      COLOR      LOCATION      DIAGRAM
12 VOLT CONSTANT      RED (+), NOTE #2      @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 1
STARTER      GREEN (+), NOTE #3      @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 3
STARTER 2      WHITE (+) and BLUE (+), (PUSH-START BUTTON)
IGNITION 1      PINK (+), NOTE #4      @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 4
IGNITION 2      N/A
IGNITION 3      N/A
ACCESSORY/HEATER BLOWER 1      BLUE (+), NOTE #5      @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 2
ACCESSORY/HEATER BLOWER 2      WHITE (+), NOTE #6      @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 6
KEYSENSE      N/A
PARKING LIGHTS ( - )      YELLOW (-)      @ HEADLIGHT SWITCH, (WHITE, 13-PIN PLUG), PIN 1
PARKING LIGHTS ( + )      GREEN(+)(Left) and YELLOW(+)(Right) use both!      @ DASH FUSE BOX, (WHITE, 40-PIN PLUG(D), PINS 2 and 1
POWER LOCK      BLUE/BLACK (TYPE B)      @ DASH FUSE BOX, (WHITE, 40-PIN PLUG(D), PIN 37
POWER UNLOCK      GRAY/BLACK (TYPE B), NOTE #7      @ DASH FUSE BOX, (WHITE, 40-PIN PLUG(D), PIN 36
LOCK MOTOR WIRE      ORANGE (5-Wire Type)      @ DASH FUSE BOX, (WHITE, 20-PIN PLUG(E), PIN 9
DOOR TRIGGER      GREEN/ORANGE (-)      @ DASH FUSE BOX, (WHITE, 40-PIN PLUG(D), PIN 24
DOMELIGHT SUPERVISION      BROWN (-)      @ DRIVERS FRONT A Pillar, (WHITE, 22-PIN PLUG), PIN 1
TRUNK RELEASE      YELLOW/BLACK (-), NOTE #8      @ DASH FUSE BOX, (WHITE, 40-PIN PLUG(D), PIN 35
SLIDING POWER DOOR      N/A
HORN      GRAY (-)      in DRIVERS KICK PANEL, (WHITE, 24-PIN PLUG), PIN 20
TACH      GREEN, BLUE, GRAY or BROWN (AC)      @ Any FUEL-INJECTOR
WAIT TO START LIGHT      N/A
BRAKE      GREEN (+)      @ BRAKE PEDAL SWITCH or in DRIVERS KICK PANEL, (WHITE, 24-PIN PLUG), PIN 6
FACTORY ALARM DISARM      PINK (-) and GRAY (-), use both, Requires Double Pulse, NOTE #9      @ DASH FUSE BOX, (WHITE, 40-PIN PLUG(D), PINS 28 and 31
ANTI-THEFT      HYUNDAI'S TRANSPONDER ANTI-THEFT SYSTEM, See NOTE #1      @ IGNITION SWITCH TUMBLER
NOTES
NOTE #1: This vehicle May Be Equipped with HYUNDAI'S TRANSPONDER ANTI-THEFT SYSTEM, check the OWNERS MANUAL for this vehcile or contact your HYUNDAI Dealer to see if the vehicle has a Special programmed Ignition Key, if it does, then for REMOTE STARTING you will need the 791 BYPASS Module and an Extra Ignition key.
NOTE #2: on Vehicles with SMART KEY, this wire is in the DRIVERS KICK PANEL, (BLUE, 15-PIN PLUG), PIN 12
NOTE #3: on Vehicles with SMART KEY, this wire is RED (+) at the DASH FUSE BOX, (REAR WHITE, 16-PIN PLUG(J), PIN 12
NOTE #4: on Vehicles with SMART KEY, this wire is at the DASH FUSE BOX, (REAR WHITE, 18-PIN PLUG(H), PIN 14
NOTE #5: on Vehicles with SMART KEY, this wire is at the DASH FUSE BOX, (REAR WHITE, 16-PIN PLUG(J), PIN 13
NOTE #6: on Vehicles with SMART KEY, this wire is at the DASH FUSE BOX, (REAR WHITE, 16-PIN PLUG(J), PIN 11
NOTE #7: to UNLOCK just the DRIVERS DOOR use the YELLOW/BLACK (-) at the DASH FUSE BOX, (REAR, WHITE, 28-PIN PLUG(F), PIN 8.
NOTE #8: TEST this wire while Opening the Liftgate from the Handle on the REAR of the Vehicle
NOTE #9: TEST this wire while Turning the KEY in the DRIVERS DOOR.
~wirewise~
Thursday, May 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
