2017 Jeep Wrangler Base Remote Start
hardermods
Posted: June 16, 2018 at 8:20 AM / IP Logged Link to Post Post Reply Quote hardermods
I'm adding power locks and a remote starter to a 17 JKU, I got the actuators all installed and working. The remote start on the other hand, not so much.
I'm using the Avital 4105L with a Fortin EvoRS-chrt5, I was told to connect all the Avital wires to the fortin, when I do that nothing happens. I ran a wire from the starter output under the engine fuse box and now the avital engages and the Jeep will crank, but it never fires up.
Evo Avital
Yellow (Ignition) ---- Pink
Purple (Lock/Arm) ---- Green/White
Purple/White(Unlock/Disarm) ---- Light Green
Green (Door Status)
White (Trunk Status)
Orange (Sliding Door, left)
Orange/Black (sliding Door, right)
Dark Blue (Ground when running) ---- Orange
Red/Blue (Starter) ---- Purple
Light/Blue (Not used)
Black (Brake) ---- Brown
Pink (Tach) ---- Purple/White
Yellow/Black(Trunk Release)
Brown/White (HandBrake) ---- Black/White
Pink/Black (Hood Status) ---- Gray (Also has aftermarket pin switch T-in)
2 power wires on the Avital are ran under the hood to the battery
Avital - Pink/White and Orange are not connected to anything
Avital - Satellite Harness is not connected
Evo - Data Link 4 pin is not connected to anything, the T of the data link, I do have the main data link plugged into the evo. I did the programming on the evo and it seems to have worked.
Sunday, November 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
