Looking To Buy Unknown Connectors. ID
jamesavery22
Posted: July 18, 2018 at 8:06 AM / IP Logged Link to Post Post Reply Quote jamesavery22
I have a cheap chinese electrical motor controller that uses these connectors and I'm looking to buy these three connectors. Any chance anyone has ever seen them before? Whether virgin or already on a harness, I'd like to buy them so I can use them on something else.
Looking To Buy Unknown Connectors. ID -- posted image.
Ween
Platinum - Posts: 1,368
Posted: July 18, 2018 at 9:14 PM / IP Logged Link to Post Post Reply Quote Ween
Hi,
Some dimensions might help. How wide are the female and male tabs? Are they .250" -- 6.3mm? or wider? On the 2 terminal housings, what is the pitch (distance between the terminals).
Also the overall dimensions of the housings for the female terminals. What dimensions would a housing need to be to fit the male tabbed connector.
More info would help.
jamesavery22
Posted: July 19, 2018 at 7:22 AM / IP Logged Link to Post Post Reply Quote jamesavery22
Ween wrote:
Hi,
Thanks. Will measure and post back.
iskidoo
Silver - Posts: 1,048
Posted: July 19, 2018 at 4:52 PM / IP Logged Link to Post Post Reply Quote iskidoo
These are similar but not exact but would give you both sides of the connection. If the link doesn’t work it’s on Amazon under “Lsgoodcare 6.3mm connector kit”.
Use the drop down selector to choose either 2 or 3 pin connectors.
https://www.amazon.com/dp/B06Y2BJD5B/ref=cm_sw_r_cp_api_BCquBbA30WAX8
Steve G
