Using a 2-Wire PATS Bypass on a 5-Wire Connector?
Simplemitch
Copper - Posts: 68
Posted: September 22, 2018 at 8:21 AM / IP Logged Link to Post Post Reply Quote Simplemitch
Hey all, this might be an easy (dumb) question, but I haven’t done a remote start in about 8 years.
I have an old CodeAlarm PC 7300 remote start that I’m thinking about putting in my 2007 Ford Focus. I bought a cheapy PATS bypass off Amazon (BANVIE Universal Immobilizer Transponder Bypass Module), which has an antenna loop for the key cylinder and a Positive/ Negative input. The code alarm has a 5-pin PATS/VATS harness with the following connections:
1. +12v
2. Ground
3. Ignition (+)
4. Starter Motor (+)
5. Active Out (-)
I’m assuming that key reading only takes place during cranking, so do you think Module Ground to Ground and Module Positive to Starter Motor (+) would work? If not, please point me in the right direction. Thanks.
Mitchell Whitney, Installer/technician
Mainstreet A/V
eguru
Copper - Posts: 340
Posted: September 22, 2018 at 8:34 AM / IP Logged Link to Post Post Reply Quote eguru
Use the Active Out(-) to activate the bypass.
You also need to drive the key-in-sense to +12V so you will need a small relay.
Simplemitch
Copper - Posts: 68
Posted: September 22, 2018 at 9:10 AM / IP Logged Link to Post Post Reply Quote Simplemitch
Thanks for the super fast reply! According to multiple wiring charts I’m looking at, the Key Sense is negative (red/black (-) at column harness). Can’t it be directly connected to the active out as is?
Mainstreet A/V
eguru
Copper - Posts: 340
Posted: September 22, 2018 at 3:42 PM / IP Logged Link to Post Post Reply Quote eguru
Whoops, sorry about the wrong polarity of key sense.
If its negative, then sure, just drive it with active out.
Regards
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
