2006 Nissan Pathfinder, Viper 5305v
tavo112085
Member - Posts: 6
Posted: October 16, 2018 at 10:15 PM / IP Logged Link to Post Post Reply Quote tavo112085
Hello !! Does anybody knows how to program the pink/white ignition 2 to be an accesory 2 on a viper 5305v. Is for a 2006 nissan pathfinder.
Tavo112085
geepherder
Platinum - Posts: 3,668
Posted: October 17, 2018 at 10:29 AM / IP Logged Link to Post Post Reply Quote geepherder
Menu 3, item 6, option 2 (2 chirps)
the manual is in the downloads section if you don't have it:
1. Open a door.
2. Turn the ignition on, then off.
3. Select a Menu. Press and hold the Control Center button. The number of siren chirps indicates the menu
number. 1 LED flash and chirp indicates Menu 1, 2 LED flashes and chirps - Menu 2 and 3 LED flashes
and chirps for Menu 3.
4. When the desired menu chirps are heard, release the Control button.
5. Select a Feature. Press and release the Control Center button the number of times corresponding to the
feature you desire to change. Then, press and hold one more time to select the features.
6. Program the Feature. While still holding the Control Center button, you can program the feature using
the remote control or by pulsing a (-) on the 24 pin White/Blue Activation Input wire.
tavo112085
Member - Posts: 6
Posted: October 17, 2018 at 11:19 AM / IP Logged Link to Post Post Reply Quote tavo112085
Thank you for the info!! My firend told me to wire it with a relay. Im not sure if that is possible!!
Tavo112085
iskidoo
Silver - Posts: 1,047
Posted: October 18, 2018 at 9:56 PM / IP Logged Link to Post Post Reply Quote iskidoo
Install Manual 5305
You may want to have this for reference.
Steve G
iskidoo
Posted: October 18, 2018 at 10:00 PM / IP Logged Link to Post Post Reply Quote iskidoo
tavo112085 wrote:
My friend told me to wire it with a relay. I'm not sure if that is possible!!
Just make sure you are using the heavy gauge pink/white wire from the 10 pin harness and you will not need a relay.
If you were using the pink/white small wire from the 24 pin connector you would definitely need to use a relay.
Steve G
iskidoo
Posted: October 18, 2018 at 10:15 PM / IP Logged Link to Post Post Reply Quote iskidoo
FYI   (The 2nd starter will require a relay)
NOTE *1 When Installing a REMOTE STARTER, you MUST use BOTH Starter #1 and Starter #2 wires. Both wires must be connected to the STARTER/CRANKING Output wire from the Remote Starter or the vehicle will NOT Remote Start when the Engine is cold.
Steve G
tavo112085
Member - Posts: 6
Posted: October 20, 2018 at 2:42 PM / IP Logged Link to Post Post Reply Quote tavo112085
Hello everybody!! I installed my viper 5305 remote starter
When i push the start button it only clicks inside the romote start but nothing happen. Any one have any idea of what could be the problem
Tavo112085
geepherder
Posted: October 20, 2018 at 6:44 PM / IP Logged Link to Post Post Reply Quote geepherder
When you try to start, do you get error chirps? Is the toggle switch plugged in/on? If you do shutdown diagnostics, how many LED flashes do you get?
tavo112085
Member - Posts: 6
Posted: October 20, 2018 at 9:52 PM / IP Logged Link to Post Post Reply Quote tavo112085
No chirps, no toggle swicht. I did no do a shut down diagnostic yet.
Tavo112085
geepherder
Posted: October 21, 2018 at 5:42 AM / IP Logged Link to Post Post Reply Quote geepherder
Also try touching the white/blue remote start activation wire to ground. See if that starts it.
Do the other functions work with the remote (arm/disarm)? If not, you could try relearning the remote. If that doesn't work, verify all your power/ground connections as well as checking the antenna cable for continuity.
