Wiring Diagram for 2007 Mazda 5 for Lock Unlock
getthingsready
Posted: November 10, 2018 at 10:15 PM / IP Logged Link to Post Post Reply Quote getthingsready
I need to install a universal keyless entry module on my Mazda 5 2007. Does anyone have the wiring diagram for my Mazda? I can't seem to find any information for a Mazda 5 2007. Thanks.
Peter
lurch228
Silver - Posts: 1,338
Posted: November 11, 2018 at 4:57 AM / IP Logged Link to Post Post Reply Quote lurch228
MODEL YEAR(S
MAZDA 5 2006-2010
KEY T-HARNESS IMMOBILIZER
N/A N/A TRANSPONDER SYSTEM, See NOTE #1
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT BLACK/YELLOW (+) IGNITION SWITCH, WHITE 8 PIN PLUG, PIN 8
STARTER BLACK/BLUE (+) IGNITION SWITCH, WHITE 8 PIN PLUG, PIN 5
STARTER 2 N/A
IGNITION 1 BLUE (+) IGNITION SWITCH, WHITE 8 PIN PLUG, PIN 1
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 RED/BLACK (+) IGNITION SWITCH, WHITE 8 PIN PLUG, PIN 6
ACCESSORY/HEATER BLOWER 2 PURPLE (+) IGNITION SWITCH, WHITE 8 PIN PLUG, PIN 7
KEYSENSE WHITE/BLUE (+) IGNITION SWITCH, WHITE 8 PIN PLUG, PIN 2
PARKING LIGHTS ( - ) BROWN/RED (+) BCM BEHIND GLOVE BOX, WHITE 30 PIN PLUG(3), PIN 25
PARKING LIGHTS ( + ) GRAY/BLACK (+) BCM BEHIND GLOVE BOX, WHITE 24 PIN PLUG(5), PIN 21
POWER LOCK BLUE (-) ONE WIRE (-) THRU 1000 OHMS LOCKS ,BCM BEHIND GLOVE BOX, WHITE 24 PIN PLUG(5), PIN 5
POWER UNLOCK SAME WIRE AS LOCK (-) (-) TO BLUE WIRE UNLOCKS
LOCK MOTOR WIRE RED/BLUE (5-WIRE TYPE) BCM BEHIND GLOVE BOX, WHITE 8 PIN PLUG(6), PIN 1
DOOR TRIGGER BLUE/BLACK (-) BCM BEHIND GLOVE BOX, WHITE 24 PIN PLUG(5), PIN 4
DOMELIGHT SUPERVISION YELLOW (-) BCM BEHIND GLOVE BOX, WHITE 8 PIN PLUG(6), PIN 3
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN PURPLE/WHITE (-) BCM BEHIND GLOVE BOX, WHITE 30 PIN PLUG(3), PIN 9
TACH BLACK/STRIPE (AC) ANY FUEL INJECTOR, WHITE 2 PIN PLUG, PIN 1
WAIT TO START LIGHT
BRAKE GREEN/YELLOW (+) @ BRAKE PEDAL SWITCH or DRIVERS KICK PANEL, HARNESS TO REAR
FACTORY ALARM DISARM N/A
ANTI-THEFT TRANSPONDER TYPE @ IGNITION BARREL
NOTES
NOTE #1 TRANSPONDER ANTI THEFT SYSTEM REQUIRES A 791 BYPASS AND EXTRA KEY FOR REMOTE STARTING. CAN ALSO USE A PKALL OR PKTX (NO KEY REQUIRED TO BE BE LEFT IN BYPASS) 2 KEYS REQUIRED FOR PROGRAMMING
twelveez
Member - Posts: 7
Posted: November 11, 2018 at 10:07 PM / IP Logged Link to Post Post Reply Quote twelveez
were you able to fix it?
Saturday, November 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
