Should I Wire Tweeters to Their Own Amplifier?
ch3vyman816
Member - Posts: 6
Posted: December 16, 2018 at 10:45 PM / IP Logged Link to Post Post Reply Quote ch3vyman816
First off I'm new to the site as a member. But idk if this was asked before. But I have some 6 1/2 three way speakers and some 1" bullet tweeters. I was seeing if I should put the tweeters on there own amp or will they be fine on the same amp as my 6 1/2s??
Ch3vyman816
eguru
Copper - Posts: 340
Posted: December 17, 2018 at 10:50 AM / IP Logged Link to Post Post Reply Quote eguru
Share the amp but use a high pass filter with your bullet tweeters.
ch3vyman816
Member - Posts: 6
Posted: December 18, 2018 at 2:30 PM / IP Logged Link to Post Post Reply Quote ch3vyman816
What's a high pass filter??
Ch3vyman816
mjoekingz28
Member - Posts: 8
Posted: December 18, 2018 at 3:04 PM / IP Logged Link to Post Post Reply Quote mjoekingz28
Why in the world do tweeters require an amplifier to begin with? A 1/2 inch tweet should? work with 20 watts. Why are they calling for 50+?
It is minuscule and has no noticeable movement.
eguru
Copper - Posts: 340
Posted: December 19, 2018 at 8:10 PM / IP Logged Link to Post Post Reply Quote eguru
A high pass filter will allow only the high frequencies to drive the tweeter basically blocking the lows from trying to drive the tweeter (and causing wasted power and distortion).
ch3vyman816
Member - Posts: 6
Posted: December 22, 2018 at 9:45 AM / IP Logged Link to Post Post Reply Quote ch3vyman816
Oh you mean like on the amp, use the high pass filter on it. I use that anyways on my highs.
Ch3vyman816
mjoekingz28
Member - Posts: 8
Posted: December 22, 2018 at 11:11 PM / IP Logged Link to Post Post Reply Quote mjoekingz28
My specialist said the impedance is negligible.
Do they still make bass blockers?
2.5-5k may help with sound and safety.
greddm
Posted: December 26, 2018 at 6:30 PM / IP Logged Link to Post Post Reply Quote greddm
Can you provide more information about the amp you are going to use? Personally, I would skip the tweeters if you have 3-way 6.5s. Thats a lot of highs and not a lot of lows which will end up making your music sound too "bright", like getting stabbed in the ears.
ch3vyman816
Member - Posts: 6
Posted: December 31, 2018 at 4:08 PM / IP Logged Link to Post Post Reply Quote ch3vyman816
I'm actually switching out my 6.5 3ways for 6.5 midrange. And right now I'm running a Jensen 750.4 amp on the 3ways and tweeters. Had it laying around.
Ch3vyman816
DYohn
Moderator - Posts: 10,741
Posted: January 03, 2019 at 2:21 PM / IP Logged Link to Post Post Reply Quote DYohn
Tweeters always require a crossover. There are crossover guides on this site. You should use a high pass crossover set at approximately 2x the fs of the tweeter.
Saturday, January 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
