2006 Camry LE 2.4L 4-cyl Remote Start Install Problems
tripod1855
Member - Posts: 6
Posted: January 24, 2019 at 9:56 AM / IP Logged Link to Post Post Reply Quote tripod1855
Geepherder, not that you care, but I wasn't able to work on this project since my last post due to work, travel and weather conditions. Nonetheless, when I got back to it, I decided to remove the battery again and take it to be tested (before wasting any more time on anything else)... turns out you were right once again, from the beginning. Although the battery would charge and hold the charge, the cranking amps were down to about 75% and would not increase with the voltage charge.
After I bought a new battery and replaced it in the vehicle, it started right up with the key. Then I re-attached the R/S unit and bypass module; and again, it started right up with the key. So, then I put it in "tach finder mode" and located the Tach Wire (at the ECM behind glove box). Everything said my Tach Wire was supposed to be on the Driver Side, but it wasn't... it was a pain in the ass running the wire behind the dash to the ECM; but, once I had the Tach Wire connected, I tried a 'remote start' for the first time, and it started right up!
I never ended up changing any of the wiring I had done, nor did I take out the relay switches. Everything worked perfectly after I replaced the battery... lesson learned.
Thanks so much for all the help.
geepherder
Platinum - Posts: 3,668
Posted: January 24, 2019 at 10:54 AM / IP Logged Link to Post Post Reply Quote geepherder
Good to hear.
Saturday, July 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
