Viper 5305V, Door Lock Actuators, Relay, Troubleshooting
tommygunna
Member - Posts: 9
Posted: May 09, 2019 at 7:31 PM / IP Logged Link to Post Post Reply Quote tommygunna
Hey Everyone,
I recently purchased a Viper 5305V with 2 InstallGear Universal Car Power Door Lock Actuators 12-Volt Motors(2 wire). I can't for the life of me figure out if I need these to go to a relay or do I just splice the three wire coming from the brain to both doors? This is for a 1994 civic VX that never had any power windows/locks.
Viper 5305V, Door Lock Actuators, Relay, Troubleshooting -- posted image.
iskidoo
Silver - Posts: 1,046
Posted: May 09, 2019 at 8:36 PM / IP Logged Link to Post Post Reply Quote iskidoo
If you aren’t adding door switches then you will need 2 relays wired as described in the following link. https://www.the12volt.com/relays/relaydiagram4.html
If you are adding door switches then the circuit will be slightly different. Do not connect the actuators directly to the viper alarm outputs. The outputs are only a 1/2 amp each and you will overdraw and burnout those outputs without added relays.
Steve G
iskidoo
Posted: May 09, 2019 at 8:58 PM / IP Logged Link to Post Post Reply Quote iskidoo
This may help you too. Don’t worry that relay terminals 85 & 86 are wired different between the 2 diagrams. It can be wired either way. I would not use the red 12v wire from the 3 pin alarm lock/unlock harness to power the relays https://shieldtechsecurity.com/support/diagrams/vehicle/TechDoc%203961%20-%20ADDING%20DOOR%20LOCK%20ACTUATORS.pdf
Steve G
tommygunna
Member - Posts: 9
Posted: May 10, 2019 at 1:37 AM / IP Logged Link to Post Post Reply Quote tommygunna
Thank you so much for the insight!
1. Would that mean 2 relays for each actuator? or can I splice the both together and then connect to the relays?
2.I know you mentioned not to use the 12v red on the alarm to power the relay, is it best to tap straight to the battery or splice in to a constant 12v source thats on the car?
iskidoo
Posted: May 10, 2019 at 3:52 AM / IP Logged Link to Post Post Reply Quote iskidoo
1 both actuators can be tied together in parallel so they will operate simultaneously.
2 constant source can be from the white constant 12v found in the ignition harness or also the battery if you prefer. Battery is not necessary though but putting a fuse is a must.
Steve G
tommygunna
Member - Posts: 9
Posted: May 10, 2019 at 12:04 PM / IP Logged Link to Post Post Reply Quote tommygunna
iskidoo,
Thank you very much for your help and guidance. It is much appreciated!
iskidoo
Posted: May 10, 2019 at 10:42 PM / IP Logged Link to Post Post Reply Quote iskidoo
Glad to help. I hope it all turns out well. Viper 5305V, Door Lock Actuators, Relay, Troubleshooting -- posted image.
Steve G
mgoetz74
Silver - Posts: 424
Posted: May 11, 2019 at 10:11 AM / IP Logged Link to Post Post Reply Quote mgoetz74
easier way would be to buy a dei 451m relay pack, plug it into the viper brain, run the purple purple/black to constant power, white/black and brown/black to ground and green and blue as your lock/unlock output to the actuators. It will run up to 2 safely
tommygunna
Member - Posts: 9
Posted: May 20, 2019 at 7:07 PM / IP Logged Link to Post Post Reply Quote tommygunna
Hello everyone,
I recently installed this and first timer. This is for a 94 civic vx and with aftermarket actuators. I got the arm and disarm to work and have tested if I open the door or hood when armed the alarm goes off. Problem now is the led light on the antenna is blinking a code of 6. I didnt connect anything for accessories but basically I just wanted a keyless entry for now and no remote start so ive only connected the following below. I bought this alarm on offerup and wasnt used from the looks of it. Didnt know if I need to do anything else program wise? Even after disarming that damn led is still flashing that code of 6 flashes
Main harness
Red
White
Brown
Black
24pin
Green - door trigger
Gray - hood
3 pin
Blue - to lock relay
Green - to lock relay
Thank you!
geepherder
Platinum - Posts: 3,668
Posted: May 20, 2019 at 8:12 PM / IP Logged Link to Post Post Reply Quote geepherder
Cycle the ignition on/off and try again.
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
