Automotive Wiring, Mass Air Flow Sensor
13magero
Posted: November 22, 2019 at 5:33 PM / IP Logged Link to Post Post Reply Quote 13magero
Hello All,
I have a mass air flow sensor that has an extension spliced Into the harness. The extension is a thicker wire than the harness. Will this create a different voltage going to my ECU than the stock harness?
Thank you
Mario
Ween
Platinum - Posts: 1,368
Posted: November 22, 2019 at 9:21 PM / IP Logged Link to Post Post Reply Quote Ween
Assuming properly made connections, shouldn't be an issue. Engine in question is a ?
geepherder
Platinum - Posts: 3,668
Posted: November 23, 2019 at 4:41 AM / IP Logged Link to Post Post Reply Quote geepherder
I agree with Ween. There should be no issue. A larger gauge wire across the extension minimizes further voltage drop (less resistance than the OEM wire). Unless the extension were several meters long or something like that, I wouldn't worry about it.
Friday, October 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
