Viper 4105, 1998 Nissan Maxima, Trunk Release
cwfalconfootbal
Member - Posts: 7
Posted: December 29, 2019 at 1:44 PM / IP Logged Link to Post Post Reply Quote cwfalconfootbal
I had a shop install a viper 4105 remote start in my car.   98 Nissan Maxima. They didn’t hook up a relay for my trunk popper so I got a relay and wires it up and it worked once. I brought the relay and harness inside to soldier what I could and wired it back up to the car and nothing. Checked the output wire and no signal was coming from it. What would cause that?
lectricguy
Copper - Posts: 359
Posted: December 29, 2019 at 5:33 PM / IP Logged Link to Post Post Reply Quote lectricguy
What wire are you wiring to? There are 2 purple/yellow wires in the driver's kick. Did you test the wire before hooking up to it?
Trunk Release     Purple/Yellow (-)      Driver's Kick Panel
Trunk Pin     Purple/Yellow (-)      Driver's Kick or BCM below Radio
I assume this is a heavy gauge wire and it requires a relay, how did you hook the relay up?
Should be:
Pin 86 to 12V constant
Pin 85 to Red/White of the 4105
Pin 30 to Gnd
Pin 87 to Purple/yellow trunk release
If it worked once, are the connections good (soldered, no taps) and does the output of the 4105 still work?
To test the 4105 trunk release, put 1 voltmeter lead on 12V constant, the other on the red/white trunk release lead. Press the 4105 fob trunk release and you should see 12V on the meter when the trunk release negative output is active (for 1 second).
Cheers
Lectric Guy
cwfalconfootbal
Member - Posts: 7
Posted: December 30, 2019 at 2:15 PM / IP Logged Link to Post Post Reply Quote cwfalconfootbal
I wired it exactly as you said. And I went to the purple/yellow at the switch which I assume it the same as the trunk release in the drivers kick. Was told the other one at the bcm wouldn’t pop if the car was started remotely. I will test with a volt meter when I buy one.
cwfalconfootbal
Member - Posts: 7
Posted: December 30, 2019 at 2:16 PM / IP Logged Link to Post Post Reply Quote cwfalconfootbal
I didn’t run the wires final yet but I know the relay works. I also know the relay pops the trunk because I wired pin 87 to the defroster circuit to test and it worked when remote started.
cwfalconfootbal
Member - Posts: 7
Posted: January 02, 2020 at 2:02 PM / IP Logged Link to Post Post Reply Quote cwfalconfootbal
My voltmeter is showing 12 volts.
silvercivicsir
Copper - Posts: 416
Posted: January 02, 2020 at 2:50 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
that year maxima needs a high current ground. if the trunk output no longer works on the 4105, you most likely blew it.
cwfalconfootbal
Member - Posts: 7
Posted: January 02, 2020 at 4:24 PM / IP Logged Link to Post Post Reply Quote cwfalconfootbal
Blew the 4105?
silvercivicsir
Copper - Posts: 416
Posted: January 04, 2020 at 11:29 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
blew the neg trunk output on the 4105
cwfalconfootbal
Member - Posts: 7
Posted: January 06, 2020 at 12:59 PM / IP Logged Link to Post Post Reply Quote cwfalconfootbal
What I don’t understand is if it reads on my multimeter that’s it has a signal how would it be blown?
cwfalconfootbal
Member - Posts: 7
Posted: January 06, 2020 at 1:01 PM / IP Logged Link to Post Post Reply Quote cwfalconfootbal
I read a ton of issues with the trunk release negative output on this site it’s insane.
